Old 04-22-2009   #1
TsiTom
TsiTom's Avatar
93 head on a 6 bolt block ?
Im in the middle of reconditioning a 1993 7 bolt head and im planning on mating it to my 6 bolt block. Ive read that the stud holes have to be brought out 1mm to fit it correctly..and I will be using ARPs. The guys who have done this: Did you send it off to the machine shop to have them enlarged?..Or is this something I can do on my drill press? Ive searched but I need a thorough explaination on how to go about this... Solid input would be appreciated! Thanks
TsiTom is offline   Reply With Quote
Old 04-22-2009   #2
iceminion
iceminion's Avatar
Re: 93 head on a 6 bolt block ?
This is actually very easy to do! I have it done on my galant.
All I did was use a 1/2 inch drill bit and drill the holes out just a tad.
It doesnt need to be an exact science because the alignment dowels in the block align the head and are considerably larger then 1/2 inch!
Good luck!
building a 3000GT AWD Turbo.
Old 04-22-2009   #3
TsiTom
TsiTom's Avatar
Good luck!
Awesome, thanks! I was hoping they could just be drilled out
Old 04-22-2009   #4
That's how I did it also. Just drilled the holes out with a 1/2" drill bit.
Old 04-22-2009   #5
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
But now you cant use a 6 bolt head anymore unless you drill that out too...
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 04-22-2009   #6
Say what?
A 6-bolt block utilizes 12mm studs. A 7-bolt block utilizes 11mm studs. Because of that, you need to enlarge the holes on a 2G Head if you put it on a 6-bolt block, as the holes are smaller, to clear the 1mm larger studs. A 6-bolt head already has the larger holes, so no enlarging is needed.
Old 04-22-2009   #7
GsXtUrBo98
GsXtUrBo98's Avatar
Say what?
oic I had it the opposite way around...
98 GSX (built)
03 BBY EVO dd
Old 04-23-2009   #8
You can even put a 6 bolt head on a 7 bolt block. It gets lined up with the guide sleaves on the corners of the block. The only one that you need to do any modification for is if its a 6 bolt block with 7 bolt head.
Old 04-29-2009   #9
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
Everyone fails in this thread.
The proper way to fit a 2g head onto a 6bolt block is shown in the following videos.
http://www.mitsustyle.com/video/MVC-001W.MPG
http://www.dsmstyle.com/video/MVC-002W.MPG
Nash doesn't monkey around
Old 04-29-2009   #10
I have heard of that video, but never seen it!!
