Old 04-22-2009   #6
Re: 93 head on a 6 bolt block ?
Say what?
A 6-bolt block utilizes 12mm studs. A 7-bolt block utilizes 11mm studs. Because of that, you need to enlarge the holes on a 2G Head if you put it on a 6-bolt block, as the holes are smaller, to clear the 1mm larger studs. A 6-bolt head already has the larger holes, so no enlarging is needed.
