Old 07-13-2008   #1
Finally, Dyno Results!!!
It's been a while since I've had the evo on the dyno with it running properly, but yesterday it finally worked out. The day before I had my doubts, as of course I blew open a massive 2" hose in my hose connecting my bov to my UICP and the car ran like crap.
I spent some good time on the street with my laptop and LC-1 getting stuff dialed in so as to minimize the headaches on shane, but really I probably only made things worse
Anyways, mod list (power stuff only, of course):
Buschur Racing 3" TBE w/ bullet testpipe
Buschur Racing Intake kit
BR Deluxe FMIC kit (3.5" core)
BR Upper IC Pipe
OEM IX BOV
HKS 280 cams
ARP headstuds
BR Ported/Coated Exhaust Mani
Ported Turbine Housing
OEM Evo IX turbo
BR SS O2 Housing
BR Ported Intake Manifold w/ EGR delete
BR 65MM TB
Walbro 255HP fuel pump
4x Kracka Vent setup w/ ebay catch-can
Aquamist HFS-1 Alky Injection Kit
FIC 1050cc injectors
GM BCS
Evo X MAP sensor
Innovative LC-1
Tephra v5 ROM w/EGT Elim & Direct boost mods
Pump gas (BP 92), ~24psi, tapering to 22psi (woot! ecu-controlled boost!)
Boost curve needs some work, but this is my low-power tune, so it doesn't get as much attention as the alky tune
Anyways, on to the fun part!
Pump + Alky, 28.5psi tapering to 22psi
As you can see, the turbo is just out of steam and dispite my best efforts and 100% DC on the GM BCS, it just won't hold more boost up top:
Overlay, what can alky do for YOU?!?!
To flip between these two tunes, I have but to push the power button on my DDS gauge (part of the aquamist kit) and bam! The power is there While on the dyno, I tested out Tephra v5 mapswitching as I am using it for a failsafe. If the alky fails, I drop down to the pump gas tune. We did a pull, and I flipped the DDS gauge off right around 5000rpms. This seems like the worst thing you'd wanna do, but I wanted to be *sure* it was working!
Flip it off, and boost drops:
And AFR stays nice and safe Success!
Comments, Q's, and criticisms welcome
Old 07-13-2008   #2
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Re: Finally, Dyno Results!!!
Nice.
Old 07-13-2008   #3
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
I'm impressed. That's a bigger difference than I ever gave alcohol injection credit for.
Old 07-13-2008   #5
Very nice!
How safe is this alcohol injection kit? Is it something that can be relied on by an autocrosser? I just imagine myself installing it, getting tuned, then having it fail and popping my engine during a run.
Old 07-13-2008   #6
Very nice!
Heh, please note the last two pics I posted. If something goes wrong, boost lowers, and the fuel and timing map from the base map (the pump gas map) is used. I have done this several times and logged *ZERO* knock during the transition. It is perfectly safe. Warrtalon on evolutionM ran an SMC alky kit and he autoX'd competitively with it for several years. He recently switched to E85.
Old 07-13-2008   #7
Okay, I guess I'm confused as to how turning the Aquamist unit off, or any error for that matter, activates the map switching. I did read up and the DDS senses flow and tank level. Water/alcohol injection is legal in Street Prepared.
Old 07-13-2008   #8
It is part of the Tephra mods to his ECU. You run a wire from one of the Aquamist's map switch outputs to the ADC0F input on the ECU.
Old 07-13-2008   #9
Pretty stock-ish looking under the hood, nothing fancy. This pic is from when I finished my Aquamist install:
I have a better setup with Kracka Vent's and the catch-can now, it's a little different now. Perhaps some day I'll get one of the new FP Red's, and it'll still look stock-ish, but put down more like 420whp
Old 07-13-2008   #10
His kit has a flow based failsafe, incase the pump is failing or the tank runs dry, I believe. And I think he has it wired so that if the main unit loses power that the ECU switches to the pump map. He shut it off during one run and it changed to the pump gas map without even a lean spike or anything.
Old 07-13-2008   #11
That's pretty good power! I'm impressed
Old 07-13-2008   #12
Well done Chris.
Old 07-13-2008   #13
craig
wants to kick mark
craig's Avatar
Drives: Battery with wheels
looks good and all on your wife's birthday
Old 07-13-2008   #14
brando
Drives: gutlass
those are pretty solid numbers
Old 07-13-2008   #15
Looks great, I'm going to take down your non-alky numbers though!!!
Old 07-13-2008   #16
yea, the pump gas tune was not really aimed towards max power, you prolly already got me beat. . Maybe less boost and more timing would make more power, but meh, I'll flip the Alky on if I wanna go fast . 320whp is still plenty fun though!
Mattd, cams and Alky . Doooo it!
Old 07-13-2008   #17
No cams, damn it! I'm not running in Street Modified if I can compete locally (ie. win/trophy) in Street Prepared without R-compounds.
Old 07-13-2008   #18
358 is a great number, thats a pretty damn fast DD street-Evo!
Old 07-13-2008   #19
I don't understand the affliction with alky injection when we have E85 all over town. $.80 cheaper than 87 octane and you can have all the power all the time without worrying about switching maps. What am I missing here?
Old 07-13-2008   #20
Some of us travel to places that don't have E85. That is my main stipulation for not even thinking of trying it.
