Old 07-13-2008   #7
Re: Finally, Dyno Results!!!
Heh, please note the last two pics I posted. If something goes wrong, boost lowers, and the fuel and timing map from the base map (the pump gas map) is used. I have done this several times and logged *ZERO* knock during the transition. It is perfectly safe. Warrtalon on evolutionM ran an SMC alky kit and he autoX'd competitively with it for several years. He recently switched to E85.
Okay, I guess I'm confused as to how turning the Aquamist unit off, or any error for that matter, activates the map switching. I did read up and the DDS senses flow and tank level. Water/alcohol injection is legal in Street Prepared.
