Old 08-07-2010   #1
Camber Tires - built in 2°
http://www.jaylenosgarage.com/extras...er-tires/#more
Pretty slick, wonder how they work/last in the real world.
Old 08-07-2010   #2
TheBlizzard
TheBlizzard's Avatar
Drives: Too Many
Re: Camber Tires - built in 2°
Cool idea, but yeah, do they work in the real world.
Old 08-07-2010   #3
Link wouldn't work on my pos phone, but these sound the same as nitto neo gens.
Old 08-08-2010   #4
polishmafia
Smells like cat poop
polishmafia's Avatar
^ No these are not like the Nitto Neo Gens. The NGs have a dense inside shoulder tread that makes the tire not wear as quickly for cars with alot of camber.
The tire this guy invented are not square. The tires have camber built into them. Basically its like this...
|_| <- normal tire (square)
\_\ <- camber tire that this guy invented.
Old 08-08-2010   #5
Instead of the tire compensating for negative camber why not just run 0* camber? As far as I can tell, that's all this tire is doing.
Old 08-09-2010   #6
MJ23FE
Levant IX
Drives: WW IX MR
They used Evo X's to test this out.
http://www.automobilemag.com/feature...res/index.html
-Jalal
Levant IX
MJ23FE is offline   Reply With Quote
Old 08-09-2010   #7
The idea makes sense, I think this will catch on big.
Old 08-09-2010   #8
NASCAR uses it...because they only turn left
Old 08-09-2010   #9
-Jalal
The data results from that test aren't huge but the verbage suggests they are way impressed. Will be interesting to see where this goes though, that's for sure.
Old 08-09-2010   #10
According to the picture in the link provided the tires have different height sidewalls and aren't actually angled like that.
What I don't understand is why you wouldn't just leave the suspension at 0 degrees and put the short sidewall on the outside.
NASCAR uses square tires like everyone else.
Old 08-09-2010   #11
MJ23FE
Levant IX
Drives: WW IX MR
Matt, I don't understand what you mean when you say that they aren't actually angled like that. The different heights of the sidewalls make the angle that you see.
If you left the suspension at 0° and put the short sidewalls on the outside you would have positive camber.
-Jalal
Levant IX
Old 08-09-2010   #12
-Jalal
Since one sidewall is shorter than the other that means the tread itself is angled 2 degrees, which is what would happen if you put 2 degrees of camber into the suspension with a square tire.
Old 08-09-2010   #13
I think the negative camber is to offset the camber of the tire and make the tire sit flat on the ground all the time. A lot of guys run -2.5° of camber in the front anyways, right, so what would happen if you took this tire and ran the suspension at, say, -5° of camber.
The interesting side effect to this tire that is kinda neat is that it eats up the road a little nicer while cruising. Totally not what I would have thought of but it makes 100% perfect sense. Instead of the force of the road traveling straight up the sidewall, it is at an angle, so the sidewalls sorta flex like an offset spring and eat some of the directional force.
Old 08-09-2010   #14
Running 0* front camber would do the same thing. The way I see it, using this tire as stated and pictured, is pointless. Negative camber is all about gaining maximum tire contact patch when the car is leaned over, running a tire flat on the ground while going straight will pull the inner edge up in a corner while a car running negative camber with traditional tires will have a larger contact patch on the road.
Old 08-09-2010   #15
Running 0* front camber would do the same thing. The way I see it, using this tire as stated and picture, is pointless.
I agree completely. 0 degrees is 0 degrees, regardless of what the wheel is doing. If the tire is flat when it's static then it's still going to want to roll in a corner, and a taller outside sidewall is only going to make that worse.
Old 08-09-2010   #16
MJ23FE
Levant IX
Drives: WW IX MR
Correct. We're on the same page regarding that.
I would think you'd get -2° front camber if you did that, no?
If you left the suspension at 0°, wouldn't there be a ton of stress on the hub?
Also, wouldn't that mess up suspension geometry and such since your suspension components would be at positive camber, but your tires would be at their static camber?
-Jalal
Levant IX
Old 08-09-2010   #17
polishmafia
Yes, Matt. I realize the actual structure and composition of the tire, and although I have many talents, drawing the concept using an ASCII character set isn't a strong point.
Old 08-13-2010   #18
CarPsyco84
CarPsyco84's Avatar
I think there may be some benefits to having the wheel 2degrees more tipped in. It might be important to note, that like they said, you would have to adjust your alignment for those tires. I would guess they were assuming the suspension and tire roll in about 1 degree so with this tire you could get the geometric benefits of having the hub -3degrees to the ground but only the wear of -1degree of camber...
-When in doubt, Moar RPM.
