Old 12-08-2006   #1
skyhigh350
Send a message via AIM to skyhigh350
Gsx cams in gs?
I have a 93 gs. I put a gsx head on it when my timing belt broke the first time. It broke again! I have another gsx head but I think a gs one would be better for it. Is this true? Or would a gsx head be better? Im sure the cams cannot be matched truely with overlap etc. should I use the gsx head with gs cams?
skyhigh350 is offline   Reply With Quote
Old 12-08-2006   #2
skyhigh350
Re: Gsx cams in gs?
Also, Will a gsx intake work? As long as I change the throttle body assembly?
Old 12-09-2006   #3
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
Re: Gsx cams in gs?
just buy a gsx
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
Old 12-09-2006   #4
rst95eclipse
Re: Gsx cams in gs?
If the GSX head bolts up, why can't you use GSX cams? Those cams were designed to fit in that head, function with that head, and open the valves in that head. Now let's move onto the intake manifold. The runners match up. Why? Because it was designed to distribute air - to that head. My advice - don't go to Napa and get a timing belt.
Old 12-09-2006   #5
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Re: Gsx cams in gs?
I have a 93 GS and I have a turbo head on it. Works just as good as the stock head. Some switch out the cams thinking that there are more power in the turbo cams however I don't see the difference.
Old 12-09-2006   #6
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
Re: Gsx cams in gs?
yup.
-Matt
'06 Acura TL
Old 12-10-2006   #7
skyhigh350
Re: Gsx cams in gs?
Yeah the timing belt was from napa and only had 8000 miles on it.. Anyhow.. Now I need new pistons.. And since I need new pistons, I am thinking about turboing it.... I'm not sure yet tho.. I think the 93 (my year) and the 90' (parts car) are 2 diff beasts...
Old 12-10-2006   #8
Re: Gsx cams in gs?
In what respect?
Old 12-10-2006   #9
skyhigh350
Re: Gsx cams in gs?
MOstly the wiring, the ecu.. I have everythign to turbo it except for the ecu. The tps sensor and Maf wiring may be the only thing holding me back from making this car turbo.
Old 12-11-2006   #10
Re: Gsx cams in gs?
Just buy a running gsx/gst/tsi they are $1000 - $2000 for a "good" one now a days.
