Old 09-17-2008   #1
Jungy
Jungy's Avatar
Drives: 10' Sierra Denali & 99' beatervette
stintered iron clutch disk
Just curious if a stintered iron clutch disk is a very bad idea for street driving? I know how it has very harsh engagement. The reason I ask is because tight now I am running a stintered iron un-sprung disk but I do have a 6 puck carbon semi-metallic disk that I could throw in it.
Jungy is offline   Reply With Quote
Old 09-17-2008   #2
Re: stintered iron clutch disk
eh just drive on it. street driving requires slipping, which that clutch probably doesnt like to do. Might cause premature wear, but who cares.
Old 09-17-2008   #3
Well if you already have the sintered iron disk in, do you think it is too bad to drive? The sprung disk will be much better. Is the current disk a puck disk?
Old 09-17-2008   #4
Jungy
Jungy's Avatar
Driving it is pretty harsh, pretty much and on and off switch. It really doesn't bother me I was just curious if running it for driving around town would cause any problems.
This is what i have in the car right now:
http://www.cimotorsports.net/motor-s...20a-sd855.html
And this is what i have sitting in my garage except mine is a 6 puck:
http://www.cimotorsports.net/motor-s...20a-sd853.html
Old 09-17-2008   #5
I am guessing they are going to be pretty close. The spung hub will be easier to drive, but it is also a 6 puck, which will be harder to drive than the full disk.
Old 10-06-2008   #6
CarPsyco84
CarPsyco84's Avatar
I had a sintered disk once, pretty much had to take off hard all the time or it chattered bad. Worked good for launches though...
-When in doubt, Moar RPM.
Old 10-18-2008   #7
lucasoil4u
Drives: talon tsi evo 3 25psi
your left leg is gonna be huge!
