02-18-2009
#1
Braaaaaaaap!
Drives: '09 Silveraydo
tehehodi/JDM 2g project car
Well ladies and gents! Pick up my car hopefully in the next week in Duluth!
Anyway it's a 95 Talon TSi FWD, but thanks to turbodomestics, I'm going to tackle the AWD swap. Looks pretty straight foward and should be fun! Since all I do is jack off everyday.....anyway, here is my plan, and let me know what you think. I expect to be in the range of 350-400awhp. Tweak it if need be!
-HX35, Bullseye housing Maperformance/Ebay
-Turbonetics Manifold (still unsure)
-Punishment Racing o2 housing
-TIAL 38MM Wastegate .9 BAR
-DSMlink V3
-2.5" Maft?
-BC 272
-Competition Clutch 2300
-255hp pump
-Fuel Lab/Aeromotive AFPR Kit
-SS fuel lines
-1350cc/1600cc Injectors
-FMIC
-All Hard Piping 2.5"
-3" custom exhaust HKS carbon Ti muffler
-Stainless steel feed, return oil lines
-Buschur Filter
-Injen pipe 4" intake
-EGT Gauge
-Wideband 02 Gauge
-Oil Pressure Gauge
-Boost Gauge
-ARP head studs
-Headgasket
-Timing Belt
-Tires Hoosier Drag tires(not exactly street legal..lol)
Peter said post it up to see what you guys thought...lmk!
02-18-2009
#2
Re: tehehodi/JDM 2g project car
If you are going AWD then why do you NEED straight up drag tires at that power?
Amsoil Dealer
02-18-2009
#3
Not at all...use some street legal tires on it so you can have fun with it on the streets!
Originally Posted by Murlo26
#4
Sounds nice; post pics when you can. JDM 2g though? Since when are DSM's JDM?
#5
Is JDM 2G the name of someone on this site or are you trying to make a JDM 2G?
02-18-2009
#6
Lot of things you may not need to get just 350-400whp.
I'd go something in bolton form with internal gate, I assume you'll be running at least 25psi on e85. Something like a e316g, 20g, or 50trim.
Keep the stock 2g manifold and port it or something
Not necessary if you stick with internal gate
-DSMlink V3
-2.5" Maft?
Stick with the stock 2g MAS, it'll be good for well over 400whp.
-BC 272
-255hp pump
Probably don't need that, deal with a little overrun. They are spendy.
-SS fuel lines
Keep the stock lines, maybe SS line from filter to rail?
-FMIC
-Buschur Filter
What's this?
-EGT Gauge
Don't bother
-Wideband 02 Gauge
Not really necessary unless you'll be doing your own tuning.
-Oil Pressure Gauge
-Boost Gauge
-ARP head studs
Make sure you get a 6 bolt motor. If you're going to do AWD with a heavy clutch you're going to risk crankwalking.
-Headgasket
-Timing Belt
Please no.
02-18-2009
#7
Originally Posted by asshanson
-Buschur Filter
What's this?
I bet he is referring to the old-style Buschur air filter. IMO get something quality rather than something that will rust and fall apart within a few years...or hasn't already fallen apart then been glued back together. Check out the air filter shootout and you should see two great choices (Perrin or Amsoil).
02-18-2009
#8
That is a bolt on.
MANY threads on this subject. A lot of people love this turbo, I'd say go for it. Stay away from the turbonetics manifold though. I'd look at the Forced Performance or something like that. Better quality and they just dropped the price on it.
02-18-2009
#9
The Injen intake is only good for a stock sized turbo, unless they make a bigger one now???
You don't need any fancy fuel lines or an aftermarket FPR, unless you plan on running 2 fuel pumps.
02-18-2009
#10
Braaaaaaaap!
lol JDM cause i'm asian...joke...not exactly jdm..hahaha
Thanks for the input!!! i'll probably take all of that into consideration...i had to write it up kinda fast cause the wifey was pushing me to go to the gym.
Air filter...i dunno i saw the air filter showdown on one of the threads and it looked like the best, but probably do a different one. The turbo, I didn't know a internal gate would hold up. but i guess it does!! awesome! even better. Tires....ya i won't do those..just want some sticky icky tires! I will post pics as soon as i can, i won't be a swifty and shaft you guys.. i'll keep it updated from time to time.  !!!
02-18-2009
#11
Smells like cat poop
Technically, I'm more JDM than you... and I'm Polish. How the hell does that work?
02-18-2009
#12
Braaaaaaaap!
I thought i needed a AFPR if i was going to run a 255hp pump? Also there is going to be a 6 bolt swap...what internals do you guys suggest or is it all personal preference?
02-18-2009
#13
Eagle wiseco or I think many have done stock internals for this power. Maybe 1g big rods and 2g pistons.
Amsoil Dealer
02-18-2009
#14
is Nashty
Drives: Cyborg from Japan
People have taken a completly stock 6bolt engine to 580whp +. I think you'd be fine keeping it stock for that power level.
-1990 Mitsubishi Cyborg 4WD-
02-26-2009
#15
Brian Spilner called...
Drives: RR EVO Viii 493AWHP Spilner Mobile(sold)
But what's the stock tranny good for? I bet thats not 580whp..I'm getting my 2g tuned at DB on tuesday
and although the engine is completely built I don’t want to stress the transmission, not quite ready to get a shepp.
02-18-2009
#16
Braaaaaaaap!
what about the afpr? I thought it was necessary? or am i reading threads wrong?
02-18-2009
#17
is Nashty
You can run the 255 on the stock regulator but you'll run rich at idle and light throttle. asshanson was just saying to deal with the richness cause afpr's there expensive. Just look around for a cheap kit. I got my aeromotive for 150 with everything.
I personally would invest in one cause my gas mileage went wwaaaayy up once I installed mine.
02-18-2009
#18
Braaaaaaaap!
well it's only 229 for a aeromotive fpr?? i think it's worth it for better gas mileage... i just want good parts thats all
02-18-2009
#19
Importevolution.com has a cheap push lock AFPR setup you could look into. It's the same one I'm running.
As others have said, you have a lot of un-needed parts on that list. I made 366awhp on LSE's low reading Dyno Dynamics on E85 and a PTE bolt on 50 trim. That was on a 30 minute horseshit tune I did the morning of, and on around 24psi. Make sure you research up a bit and ask plenty of questions, before wasting money.
02-18-2009
#20
How does an afpr get you better gas mileage?? That clutch is probably not going to last long at 400hp either, I would get something beefier.
| Thread Tools |
| Display Modes |
Hybrid Mode
