Go Back   MitsuStyle > Hosted Support Forums > LSE Performance
Closed Thread
Old 03-10-2007   #441
Re: Finally getting stuff done on our cars
Spool isn't the problem, it's averting enough exhaust gases away from the turbo to keep the boost at a steady level. With a divided manifold and a single gate, the turbo is seeing less exhaust pressure from two of the runners than the other two. A single wastegate on a tubular manifold is usually plumbed into a merged collector, not a divided. This is similar to the way Buschur used to weld an HKS external on the number one runner of a stock manifold or the old cast T3 manifolds. I'm guessing this will cause some erratic boost control with this size turbo, but practice outweighs theory everytime. We'll see how it comes out. It shouldn't be that tough to add another wastegate later.
Goat Blower is offline
Old 03-10-2007   #442
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Id be worried with high back pressure on 2-3 and low back pressure on 1-4. When the wastgate is open. But like Steve said people have been running gates of the #1 cly forever. I would try to do a single setup like in these attached pics.
ID:	5251   Click image for larger version
11.35 @ 120mph
carltalon is offline
Old 03-10-2007   #443
Yeah, it should be fine. how big is the plunger/valve on the greddy type R?
FattyBoomBatty is offline
Old 03-10-2007   #444
Shane55113
Now 20% less Racist
Shane55113's Avatar
Sweet! i am impressed with the way the Galant is setup.
Shane55113 is offline
Old 03-12-2007   #445
I did plan on running the waste gate off the two collectors right befor the turbo and weld in a divider so there would be only a little cross over with the #1/4 to the #2/3. My thought is this turbo is huge, big, massive, the #1/4 will be full bore on the turbo but the #2/3 would have exhaust gas energy wasted. So I do not know how well a 1liter 2cylender motor would spool/keep a GT4202 spinning, 2 waste gates it is I guess.
Pushit2.0 is offline
Old 03-12-2007   #446
There is another way.
Old 03-12-2007   #447
I thought of that as well. Unfortunately, that would defeat the purpse of keeping the runners separated.
Matt D. is offline
Old 03-12-2007   #448
Not really unless you're running real low boost.
Old 03-12-2007   #449
That was my first plan, I do have room under the turbo or under the primary runners, we will see. I would have it divided all the way to the bottom of the valve seat, which should be close enough.
Old 03-12-2007   #450
PSI2HI
Send a message via AIM to PSI2HI
Originally Posted by Pushit2.0 View Post
http://www.lseperformance.com/galler...g2_itemId=3324
The waste gate will only be on the #2/3 collector, so the manifold will stay divided, if it runs less then 30psi I will be happy, race gas and track times are all I care about right now. If the boost goes low enough it will get a full pump gas tune, if not I will add another waste gate off the #1/4 collector.
Your only gonna run the gate off 1 side of the collector??
PSI2HI is offline
Old 03-12-2007   #451
It was an idea, but I will put two 38s and be done with it, so it will be a true divided manifold.
Old 03-15-2007   #453
Originally Posted by rst95eclipse View Post
When, oh, when will Josh Swanberg finally release his choice in turbo/turbos?
Once we are done testing and get some track times, I will release my new setup information.
niterydr is offline
Old 03-15-2007   #454
rst95eclipse
Sounds like there are some expectations. Is there a particular reason why you wouldn't release the information? In the past, you have been quite boisterous about the setup.
rst95eclipse is offline
Old 03-15-2007   #455
Dual 2G DSM T25s with a 900 shot of NAWZ.
Shane@DBPerformance is offline
Old 03-15-2007   #456
b00stcreep21
I hate everyone
b00stcreep21's Avatar
^^^ Who told?!?!
b00stcreep21 is offline
Old 03-15-2007   #457
Dammit you promised you wouldn't tell!
niterydr is offline
Old 03-15-2007   #458
Motha fucka!!! Now everyone will know and swanny won't be shit.
Sucks for you. Well at least rst will be there for ya. he seems a little interested in your setup these days.
turbotalon1g is offline
Old 03-16-2007   #459
Alright I will tell you what I am running.
Twin tial 38mm wastegates with leaded valves and a tial BOV.
All in blue.
niterydr is offline
Old 03-17-2007   #460
I know I know, You switched the internally gated exhaust housings for non-internally gated ones. You sly dog you.
Closed Thread
