Old 03-11-2008   #61
Re: Venturi vacuum pump
His brother has an account too, maybe he will chime in for him
Old 03-11-2008   #62
Whats his screen name?
Old 03-11-2008   #63
I don't remember, he changed it a while back.
Old 03-11-2008   #64
lol. Well, I'd be down for a GP on some cheap industrial check valves that we can rig up ourselves. Does anyone know of a website for something like that?
Old 03-11-2008   #65
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
I still have 4 left from my mod!!!
It was cheaper to buy a pack of 6 then it was to buy 2.
I will find the website later and post it in a different forum and show the proper way of hooking it up (with catch cans!)
One key thing is that you still need a proper working PVC valve with this setup i believe.
Old 03-16-2008   #66
Is there a 1 way valve on the line from A1 to your "venture" (brass T) devise? If there is this setup would not work any better under boost then stock. I do not see it working better then stock at all, you said your self the intake pipe does not make any vacuum. Also if you want to hawk your crap to the masses here contact scheides and set up a vendor account, then you will not be banned at least. If you really want a vacuum on the crank case then a mechanical pump will work better then any setup you buy from Ace Hardware.
Old 03-17-2008   #67
Shotgun!
Totenritt
Shotgun!'s Avatar
You just keep hitting the nail on the head!
Old 03-17-2008   #68
Wouldn't those check valves at least be better than OEM?
Old 03-17-2008   #69
Yes. Most factory PCV valves leak boost into the crankcase. I actually now have my own brand of these Krank Vents that I am testing out on my car and Scheides' car.
Old 03-17-2008   #70
Andrew7dg
Andrew7dg's Avatar
Kracka Vents??
Old 03-17-2008   #71
Originally Posted by Andrew7dg View Post
Kracka Vents??
LOL hell yea!
I've been a fan of Krank Vents for quite some time and I used them on my S2k with great results, but I did realize they are really expensive for what you're getting.
Old 03-17-2008   #72
Andrew7dg
Andrew7dg's Avatar
Wasn't this why iceminion was band for a little bit because of promoting his product?
However here are the places where I found mine.
Here are some places to buy the check valve
http://www.usplastic.com
Check valve that I have
http://www.usplastic.com/catalog/var...ant%5Fid=64175
Better check valve
http://www.usplastic.com/catalog/var...ant%5Fid=22297
another place
http://www.mcmaster.com/
Part #7775K63
or the MitsuStyle Kracka Vent
Old 03-17-2008   #73
I don't have anything for sale. Thats enough about these in this thread though...more to come in a few days when I make a new thread with more info
Old 03-17-2008   #74
I like the price of those plastic check valves. I wonder if they will really hold 150psi without blowing out? I am slightly concerned about their ability to function once they get some oil sludge build-up though.
Old 03-17-2008   #75
Just be carefull with the "my products for sale" part of this discussion. We have rules.
Old 03-17-2008   #76
I know the rules; I don't currently have anything for sale nor did I offer to sell anything to anyone
Old 03-17-2008   #77
I will be selling rides in my car once it's done, is that against the rules here?
Old 03-18-2008   #78
Andrew7dg
Andrew7dg's Avatar
Have been tested at 80psi, no leaks. I think with my car at 15 psi, it will do just fine.
Catch can should take care of oil sludge build up. It also states that it is a gas/liquid check valve.
For the price, if it does fill up with crud, I will put another in, I have a couple of these when I ordered them. They are that cheap!
aren't you worried what will happen if yours fill up with crud?
What is in your metal check valve that makes it seal? It is a metal seal? Plastic? rubber? you should cut one in half to show how it works
Old 03-18-2008   #79
There is a place near my house that manufactures check valves, I should check them out! www.specialtymfg.com
Old 03-18-2008   #80
i have mine setup the same way yinyang does, and get the same results i was gonna weld a tube into my exhaust to create suction at all levels.
I was reading a post on some other site about doing it, apparantly a lot of people have been doing that for a long time.
