Old 03-16-2008   #11
Re: Venturi vacuum pump
Is there a 1 way valve on the line from A1 to your "venture" (brass T) devise? If there is this setup would not work any better under boost then stock. I do not see it working better then stock at all, you said your self the intake pipe does not make any vacuum. Also if you want to hawk your crap to the masses here contact scheides and set up a vendor account, then you will not be banned at least. If you really want a vacuum on the crank case then a mechanical pump will work better then any setup you buy from Ace Hardware.
