Old 06-22-2009   #1
travail
travail's Avatar
Drives: EV0 8
Need help!!!!!!!!!!!!
OK I put a new head gasket in my evo 03 and when I went for a test run I saw that I was hitting 23lbs of boost and I was told buy the guy I got if for that it was set at 18lbs so I lower the boost and now I CAN"T REV OVER 4500RPM and it is making about 9 to 11lbs of boost. I have a switch for my AEM one setting is for 93 at 18lbs and the other is for 110 at 23lbs. I for got that I had this switch before I lowed the boost. I tried to raise the boost but nothing happen. So I really need help on this one.
travail is offline   Reply With Quote
Old 06-22-2009   #2
Re: Need help!!!!!!!!!!!!
Get your car retuned by Shane @ DB. There is no reason to only be running 18psi on 93 octane. I'm running 25psi on BP 93 Ultimate with the stock Evo IX turbo.
Old 06-22-2009   #3
Take it to shane and get it tuned/troubleshooted before it blows up again. Seriously, do NOT fuk around!
Where did this car come from anyways? 2.3/35R sounds like fun! Share pics/info!
Old 06-23-2009   #4
travail
travail's Avatar
Drives: EV0 8
EAGLE 2.3 STROKER W/ WIESCO PISTONS & EAGLE RODS EAGLE CRANK.
ARP HARDWARE THROUGHOUT THE WHOLE ENGINE
BUSHUR TOP MOUNT GT35R
RNR FULL EXHUAST SYSTEM
SPEARCO FRONT MOUT INTERCOOLER WITH 2.5" INTERCOOLERPIPING..
DLI IGNITION & C.O.P SETUP
AFTERMARKET INTAKE MANIFOLD W/ 70mm ACUFAB THROTTLE BODY..
CROWER VALVE SPRINGS AND REATIANERS
3 ANGLE VALVE JOB
1MM O/S SS VALVES
AEM ENGINE MANAGEMENT
EXEDY PRESSURE PLAT W/ CLUTCH NET 4-PUCK CLUTCH
ADJUSTABLE VENOM CAM GEARS
SHIFTGLOW BOOST/ A/F & OIL PRESURE GAUGES
TEIN LOWERING SPRING'S
TIAL BOV & WASTEGATE
SMALL STINGER BATTERY
HKS 280 CAMS
TOYO RADITATOR
Old 06-23-2009   #5
And in the meantime DO NOT BEAT ON IT!!
Old 06-23-2009   #6
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
You never answered Scheides question, haha.
'04 Honda Ricer: stock
Old 06-23-2009   #7
mike55112
mike55112's Avatar
Drives: 04 evo
Geez, you had to replace your head gasket too. You make 3 of us with evo's replacing head gaskets in the past week.
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 06-23-2009   #8
mitsu'97
Drives: 1994 Honda Civic EX SOHC VTEC!!!!
Send a message via AIM to mitsu'97
Mike, you had to replace your head gasket?
"IF YOU CANT STAND BEHIND OUR TROOPS, FEEL FREE TO STAND IN FRONT OF THEM."
mitsu'97 is offline   Reply With Quote
Old 06-23-2009   #9
mike55112
mike55112's Avatar
Drives: 04 evo
Ya.
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 06-23-2009   #10
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
damn that is crazy. Boost is trully like a (expensive illegal drug). once you try it, you're hooked. I know I am... I hope everything goes well man.
ლ(ಠ益ಠლ)
Old 06-25-2009   #11
travail
travail's Avatar
Drives: EV0 8
I think I may have found out why I can't make any boost. I was looking on some other forum and I read that other people were having the same thing happen to them and It's a boost leak or a bad wastegate. I had this happen the first time when I got the car when it wouldn't let me rev over 4500RPM in neutral. So I was thinking it was a launch control set up for the AEM. I have a way to test the wastegate to see if it's bad. It make sent because the wastegate is what make the boost right and by using a boost controller you are controlling the amount of boost that the wastegate makes. I have tryed to raise mine back to 23lbs and know matter how much I raise the boost up it wont make over 10lbs.
Old 06-25-2009   #12
twack
It was a auto get over it
twack's Avatar
No offense but it seems like you bought something that was a little over your head and your shooting in the dark. Yes the wastegate is what makes boost but with a leak to the wastegate you would get to much boost no to little. But im still for boost leak or ignition problems. I would just take it to MAP or DB and be done with it
Old 06-25-2009   #13
travail
travail's Avatar
Drives: EV0 8
Thanks for your input. But I don't think I am in over my head this is just the first turbo car I have ever owned and I have learn a lot already about the car.I am making a boost leak tester today and I a getting a laptop so I can see what the AEM is showing what the car is doing.
Old 06-25-2009   #14
So you're trying to get it to make boost again without having any idea what's going on in the engine? I would suggest you stop now and let someone who knows what they're doing fix it. If you continue on this path too much longer, it could end up getting very expensive for you.
Old 06-25-2009   #15
twack
twack's Avatar
Ya its just a lot of a turbo car to start out with. Just to start off you need a boost leak tester, compression tester, and dear god you need a laptop for that car before you even buy the car. trying to help
Old 06-26-2009   #16
travail
travail's Avatar
Drives: EV0 8
I made a boost leak tester, I got a ladtop now I will find out after work today on what the deal is.
Old 06-26-2009   #17
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
Have you compression and leakdown tested it to make sure your headgasket swap was successful?
Style's automotive engineer
Old 06-28-2009   #18
travail
travail's Avatar
Drives: EV0 8
I know what is was & fixed it
Old 06-29-2009   #19
Constant_Project21
Constant_Project21's Avatar
Drives: E36
I know what is was fix it
Not terribly sure what that means, but I'm guessing it means you figured out what was wrong and fixed it. What was the problem?
