Old 06-25-2009   #11
travail
travail's Avatar
Drives: EV0 8
Re: Need help!!!!!!!!!!!!
I think I may have found out why I can't make any boost. I was looking on some other forum and I read that other people were having the same thing happen to them and It's a boost leak or a bad wastegate. I had this happen the first time when I got the car when it wouldn't let me rev over 4500RPM in neutral. So I was thinking it was a launch control set up for the AEM. I have a way to test the wastegate to see if it's bad. It make sent because the wastegate is what make the boost right and by using a boost controller you are controlling the amount of boost that the wastegate makes. I have tryed to raise mine back to 23lbs and know matter how much I raise the boost up it wont make over 10lbs.
travail is offline   Reply With Quote
