Old 05-03-2010   #161
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
Re: 1992 Eagle Talon TSI Project
wired his ignition system backwards.
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Old 05-03-2010   #162
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
what swifty said
Old 05-03-2010   #163
LingLing
AznKraut
LingLing's Avatar
Swifty beat me to it.
Old 05-03-2010   #164
Swifty1638
Swifty1638's Avatar
I thought you asians where fast..
Black 1GB Mafia #1
I wanna go fast.
Old 05-03-2010   #165
Sweet! Now do some break in miles to seat that ring, and lets see this puppy at the dyno day!
Old 05-03-2010   #166
LingLing
AznKraut
LingLing's Avatar
Does it run 10's yet?
Old 05-03-2010   #167
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Exactly what I said! Sweet! Glad ur cars up and running
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 05-03-2010   #168
Yes she finally runs.
I had checked everything and even swapped the wires earlier but this was when the injector resistor pack was plugged into the wrong one.
I was doing some break in today, couple vacuum pulls from around 5000 and letting the engine brake the car. Transmission is great, no grinds whatsoever.
Couple things i need to figure out:
- There is a vacuum leak somewhere i have to find, likely coming from the IC Piping due to the retarded Radiator hose couplers (2 of them).
- The Prosport boost gauge is not reading boost, it just spikes to 35. I was running it between the FPR and the Intake Mani, not sure if thats how 1gs do it. but may try another port.
- The HIDs are not working. I have one new ballast so im thinking its somewhere in the wiring to the switch.
And Finally.....
The newest stupid thing... We took the car to the movies tonight to watch Alice in Wonderland... Car drove fine there, parked and locked the doors. Go in and watch the movie, come out and try to open the door..... yeah the fucking key doesnt work in the doors. Im really not sure how i missed this as i have had the car for 4 months now. but never locked the door and checked if the key opened it. There seems to be something stuck in the lock on the drivers side, but the locks on the passenger and trunk dont work either. Fuckin hell. So looks like i will be replacing the locks in it. The funny thing is, we went to the local MANN theater because it was closer to the house so if the car didnt run we could always walk home. Well we walked home for an entirely different reason.
But i was able to get in, so thats that. and the car started just fine.
Old 05-03-2010   #169
go off of the "P" port on the TB for boost gauge.
haha, my 1g does the same thing with the doors, its like the best security system evar!! except my trunk opens.
Old 05-03-2010   #170
Thanks. Usually on the 2gs you go off the little fuel solenoid.
Old 05-03-2010   #171
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
I have my boost gauge ran off my vacuum hose that goes the the fpr. Been fine on mine like that for the past 3 years.
-1990 Mitsubishi Cyborg 4WD-
Old 05-03-2010   #172
im thinking its in the wiring. something i probably did. it wasnt installed by him so i cant fault him for that.
Old 05-03-2010   #173
LingLing
AznKraut
LingLing's Avatar
Haha, Tom got owned by his car already.
How did you get back in? Pop out your sunroof?
Old 05-04-2010   #174
Awesome man! Keep breaking it in, the dyno day is so close!
Old 05-04-2010   #175
If you just remove the door lock cylinders, and bring them to a lock smith along with the key that works in the ignition, they can adjust them so that they work together. That's what I did when someone stole 1 set of keys from me. I bought a new ignition cylinder that came with new keys, then I just popped the door locks and trunk lock out, brought em in, and it was maybe like $8 per cylinder for them to adjust.
Old 05-04-2010   #176
Nice. there is a lock smith near me at ace hardware. ill do that.
I figured out most of the issues.
The HIDs were plugged in backwards. so now they work and are adjusted. i love watching them come on. yay.
The vac leak was on the turbo, the inside bolt on the j pipe wasnt all the way tightened. so i put a new bolt in there and used silicone on all of the couplers to make sure the seal is good.
Also put in a new bolt in the throttle body, one of them was too short.
Im sure the boost gauge is just the signal wire, will be looking at that in a moment.
Im going to put the power steering pump back in as soon as i find a full setup for sale. No power steering sucks ass for a wimp like me. lol
Old 05-04-2010   #177
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Whats with you plugging in things wrong? lol
Old 05-04-2010   #178
I fail i fail i fail. ok are you happy dammit.
Old 05-05-2010   #179
Boost gauge fixed - Check (ground wire on the sender wasnt hooked up)
Door locks fixed - Check (The key was correct, but the locks were soo gunked up and corroded that they wouldnt turn)
Boost/vac leaks fixed - Check (Main leak was on the J pipe, but used silicone RTV on all couplers to make sure no other leaks were present)
HIDs fixed - Check (plug was reversed)
Crossmember installed - Check (Forgot to install the drivers side one so i did that tonight, car didnt come with a passenger side one, but oh well)
Still need:
Power steering!
Windshield
More break in miles
A good wash
New paint job.
Emergency brake! (car tends to roll down the driveway if i just keep it in gear where i need to actually put a peice of wood behind the wheel.)
Old 05-05-2010   #180
LingLing
AznKraut
LingLing's Avatar
Good work, Tom. Sure is nice to see this thing running!
