Old 01-31-2010   #1
1992 Eagle Talon TSI Project
Ok so i figure its getting close to the project start. Hopefully it freakin warms up soon. Unless someone has a nice garage heater they can borrow me.
Phase one is to get the car running with the least amount of pain and money possible. Ive decided against pulling the motor at this point due to weather/time involved. Will likely do this during the summer when i can actually think without getting a brain freeze.
Phase One:
- Pull head, Pull #4 piston, Attach new Manley I Beam rod. Attach to crank with new rod bearings.
- Replace Rod Bearings for 1-3 rods to keep everything even.
- Clean up engine bay wiring. Finish install of Crane Cams Fireball Ignition. (Decided to keep the ignition, if i decide to pull it later who knows.)
- Retorque any bolt i see.
- Hook driveshaft back up.
- Verify car will start, run, and drive.
- Pull seats, and carpet. Use carpet cleaner to clean carpet and renew its original cleanliness
- Purchase and install new headunit (Just need a cheap stereo with a USB hookup)
- Repair seat tears.
- If Stephan cannot get the center console or back seat, i will be looking to puchase these along with the rest of the interior.
- Replace front fenders.
- Purchase and install Emergancy Break lever and anything missing there.
Phase Two, will be after the wedding (July 3rd). This will be where the car turns from Fun car to fun and Fast car.
- DSMLink V3 with GMMAF setup.
- 900+ cc injectors
- Large Turbo
- Built Head
- Cams
- Possible Water to Air Intercooler
- 255 Fuel Pump
- Better Exhaust
- Tune Tune Tune.
Old 01-31-2010   #2
Re: 1992 Eagle Talon TSI Project
I have a kerosene torpedo heater you can use. Pick up some kerosene at Fleet Farm, plug it in and you're set.
Old 01-31-2010   #3
That would be awesome. All i have for heaters are 2 small room heaters, that dont produce enough heat in the garage. Where are you living nowadays?
Old 01-31-2010   #4
Shoreview, right off 694 and Lexington.
Old 01-31-2010   #5
Thanks Matt, looking forward to putting the garage heater to work this week.
Old 02-03-2010   #6
Addendum to phase 1. Also need to replace a piston. Its cracked right on the one of the holes that the wrist pin goes through. YAY.
Im about 99% sure the valves are not bent. BUT, and im doubting this will affect anything, The piston slapped the head and left a mark on the head where it goes flat on the intake side, the mark is very slight and there is no cracks there. I should really take pictures and post them up. The rod was really fucked up.
Old 02-04-2010   #7
Seriously? WTF.
Get that thing rebuilt, especially with your goals.
Old 02-04-2010   #8
93tsiawd
Drives: 90 gst
i have a 6 bolt head if ur interested
99 Jaguar XJ8 (cruiser)
96 Civic Ex (sold)
90 Eclipse GS-T (sold)
90 Talon Tsi Awd (sold)
97 Talon Esi (sold)
93 240sx S13 (sold)
88 Rx7 Fc (sold)
93tsiawd is offline   Reply With Quote
Old 02-04-2010   #9
What large turbo are you thinking?
Old 02-04-2010   #10
Where would be a good place to have it resurfaced? Like i said, its basically just a scratch where the piston hit. i think a simple resurface would probably make it look like nothing happened. This head has nothing to do with my goals. I would change that out for a ported 2g head.
Old 02-04-2010   #11
Still up in the air on that one. I have been kinda toying with ideas anywhere from a GT37r, GT35r, or something. Definitly want a BB turbo.
Old 02-04-2010   #12
GT37r?
Can we not use AMS fanboy names for stuff? T67? 67mm sized turbo?
Why BB? How fast you want to go?
Are you another swifty? lol
Old 02-04-2010   #13
T88 or bust.
Old 02-04-2010   #14
My last car i had a SCM6152e. I want something that spools faster and makes more power. Not sure what you mean by AMS fanboy, as FP makes one as well. I thought you were banned. Maybe i shoudl make you purple again. LOL
I have been a fan of big turbos since my Burnt white car with the 50 trim. I am not a big fan of the 16g heros
Old 02-04-2010   #15
FP makes a 37r? I think you mean AMS, they are the ones who started that name for 67mm turbo. I couldn't find a 37r anything on FP's site.
50 trim, big turbo, hahahha.
I'm just ribbing you so don't cry. Sounds like you have a fun beast planned.
From what you say about the scm61, I think a billet 6262 would fit the bill perfect.
Old 02-04-2010   #16
maybe im thinking of a 32r? My friend down in cali had his car built with either a 37r, 32r or maybe it was even a GT30.... too many freakin numbers to remember.
Im not crying at all, maybe i have my numbers mixed up.
And back when i had the 50 trim, the GT35r was a massive turbo, but by todays standards a GT42 is a streetable turbo. HA HA .
Old 02-04-2010   #17
Im compensating for something i think which is why i want big turbos....
Old 02-04-2010   #18
kevin 1g drummer has a gt3076 dd for sale if you want to go that way
Old 02-04-2010   #19
the turbo upgrade isnt coming until after july, so i can plan accordingly and get a wedding paid for. :P
Old 02-04-2010   #20
As far as the piston meeting the head, you really should get the head checked out before you slap it all back together only to find out you have a bent valve so you can pull it apart all over again. Please do not turn this into an "I told you so" fest.
Ride in an Evo, that will change your mind about 16Gs.
