Old 07-16-2010   #221
Re: Progress since last year
Fuel issues FTL.
Old 07-17-2010   #222
URV8SUX
URV8SUX's Avatar
damn that sucks you really can't rely on that pump, twin walbros will make 1000whp.
Old 07-17-2010   #223
I just bought an A1000, good luck with the fuel lab pump.
Old 07-18-2010   #224
santa
Boost Spike
santa's Avatar
The pump works great on high speed!! I drove it to work on Friday. I got about 5 minutes into the drive, and flipped it to low speed to see what would happen. To my surprise it worked great! So, I'm going to use it for now, and see what Fuelab guys want me to do. The car felt really really strong doing some part throttle pulls. I'm seeing over 20psi part throttle before 4200rpm! The power band is going to be pretty braud. I've been wanting to keep this pump because its not noisy (My car is a street driven car) like the A1000 or the eliminator. If I do end up switching to a different pump it will be the eliminator.
Nate I don't want to deal with the wally's. When one starts to lose its potential, and the car slowly start running out of fuel. Not knowing the pump's doing that is not something I'd like to risk. Like I said before I don't want to have to worry as well about running out of fuel if and when I want to make more power.
Old 07-18-2010   #225
^I need a ride that spools way too fast.
Old 07-19-2010   #226
Get something with a bigger engine.
Old 07-24-2010   #227
santa
Boost Spike
santa's Avatar
Tuned on 27-29psi on the street right now. Feels pretty good! injector duity is at about 80% and I have my fuel pressure at 38psi lol. I was still taking fuel out of it just to get it to come off of the 10.0:1 on the wideband.
Old 07-25-2010   #228
TheBlizzard
TheBlizzard's Avatar
Drives: Too Many
So what did it make at 29psi? Did you leave out that tidbit of info just so we'd ask?
Old 07-25-2010   #229
311evo
311evo's Avatar
He said it was street tuned, hard to get good number from that.
Old 07-25-2010   #230
santa
Boost Spike
santa's Avatar
Now that I looked closer at the boost its at 25psi right now. I'll get some numbers here soon!!
Old 07-25-2010   #231
TheBlizzard
Drives: Too Many
Thats what I get for half reading posts at 3am.
Old 07-29-2010   #232
santa
Boost Spike
santa's Avatar
Hitting the dyno tomorrow night around 8pm.
Old 07-29-2010   #233
Oh snaps, looking forward to see what this thing makes!
Old 07-29-2010   #234
I am there. Ok maybe not, but thats great news, good luck.
Old 07-30-2010   #235
santa
Boost Spike
santa's Avatar
Should be leaving here (at work now) around 8:30. Hope to have the car strapped down around 9 and give the boost controller a few cranks. I'm hoping for some big numbers but, you never know what will happen with these cars lol. Shooting for 35psi on e85. Anyone want to venture a guess on hp numbers?
Old 07-31-2010   #236
That billet 6765 seems like a darn good turbo. If I had my good tires on the car I would have thought about running you.
Old 07-31-2010   #237
santa
Boost Spike
santa's Avatar
Yeah, that turbo seems to get the job done. I didn't think there would be a 200whp gain from 10 psi. After I got it on the street I had some ignition issues. I'll be putting in one of those new aem ignition box's to fix that.
Old 07-31-2010   #238
santa
Boost Spike
santa's Avatar
Well, hit the dyno and had some issues... I hooked my vacuum lines to the bottom of the waste gates instead of the top. So, I was trying to make boost that way. I was stuck at 25psi making like 560hp, then I had a buddy look at my stuff, and he call me a retard, which I accepted the failure lol. I then hooked my lines to the top of the gates, and did a quick pull to see what boost was at. I ran out of time. At map you have to stop dyno'n at 10pm or else the cops show up pissed. So it was half assed tuned, and hit 35 psi quickly and missed a little. I let off as you can see on the graph. It made 734awhp, and 593ft lbs. I need a ignition box, and that's about it.
The 530hp is my last year set up. Switching to the top mount manifold has been a great change and also the turbo selection is awesome. This thing is a beast on the street for sure! I lost no spool up time with the new manifold. I'm very happy with the setup so far! If you look really close my tq hit is actually about 2-300rpm sooner then last year.
Old 07-31-2010   #239
Wow Awesome power man!
Old 07-31-2010   #240
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Wow, nuts man! I shouldve stick around work for a little while longer and seen it in action! Are you coming back for a retune? Or gonna wait to get an ignition box?
