Old 07-29-2010   #1241
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: Evo X upgrades
He's not sure right now...no compression in 3 of 4 cylinders, sounds like the motor is dead now. Funny thing is he went back to stock and was on all stock components...one theory is a piece of the wheel may have gotten into the motor after the failure.
Old 07-29-2010   #1242
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Yeah, I exchanged a couple PMs with him on EvoXforums. This is the same guy that swapped turbos 5 or 6 times (outdoors), in front of his townhome. He's industrious but I don't know if he's competent.
Old 07-29-2010   #1243
Murlo26
Murlo26's Avatar
Re: Evo X upgrades
Jake's Evo couldn't help but come to mind when I thought of his situation, drill bit in the motor, lol. Hopefully it was something like that and not the turbo.
Old 07-29-2010   #1244
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
WGA arm fell off his turbine/wastegate flapper.
scheides is a fucking genius.
/case closed
Old 07-29-2010   #1245
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
Re: Evo X upgrades
LOL nice work. Glad its fixed!
Old 07-29-2010   #1246
Murlo26
Murlo26's Avatar
Re: Evo X upgrades
LOL, +1 for Scheides i guess. did the clip come off or something?
Old 07-29-2010   #1247
Re: Evo X upgrades
Cotter pin FTW!
Old 07-29-2010   #1248
Re: Evo X upgrades
/case closed
LMFAO! How the hell is that possible! It happened on the SAME DAY! Unreal. Slap that thign back on and boost boost boost!
Old 07-29-2010   #1249
bananas
bananas's Avatar
Drives: A4
Re: Evo X upgrades
/case closed
Crazy!
http://www.youtube.com/watch?v=6dmraBaOmtU
My fix:
bananas is offline   Reply With Quote
Old 07-29-2010   #1250
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Originally Posted by bananas View Post
Crazy!
I picked up a clip with a lock as well. It's a little longer than I'd like but I hope it works. I'm going to run to scheides' tonight since getting the arm back in place with compressed air would be a lot easier than strongarming it.
Old 07-29-2010   #1251
Murlo26
Murlo26's Avatar
Re: Evo X upgrades
First time i did the WGA tightening i used my hands, it was real hard, and actually i had to back it off one turn because i just couldn't get it...second time was at noob mod day at Scheides...WAY EASIER! Good choice.
Old 07-29-2010   #1252
Re: Evo X upgrades
I say enlarge the holes and run a suitcase padlock
Old 07-30-2010   #1253
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I'm sitting at the office and dreaming about the short course at BIR. I can't wait for the next TTM date on the 23rd.
Scheides helped me square away the WGA issue in just a few minutes last night. I hung out for a couple hours and handed him tools...I think there was only one bolt holding the turbo/manifold on when his 11pm curfew rolled around.
Old 07-30-2010   #1254
Re: Evo X upgrades
lol curfew. Glad to hear its taken care of. If you are cruising around I should be wrenching a little bit before hitting the streets myself tonight.
Old 07-31-2010   #1255
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Not a great start to the day. Was driving over to Dad's to do an oil change and heard a strange sound...started looking around and discovered a nail in one of my tires. No problem, I paid the stupid 'hazard' insurance at Discount Tire and ran over there.
Turns out that Stellar had stripped out some of the aluminum caps that screw into my Rays lug nuts. I had previous noticed a couple light scratches in my rims that weren't there before but shrugged it off since I wasn't 100% how they happened. No doubt about this one.
It'll probably take an easy out to get it off...then the misery of trying to special order a JDM replacement part (often can't be done and you have to buy a complete new set). Discount has a new tire on order for me, anyway.
Old 07-31-2010   #1256
Re: Evo X upgrades
That gets two sad faces:
Old 07-31-2010   #1257
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Think I should go buy an easy-out and an electric drill? I'm not sure if I should wait and bring it to Stellar or not. That's a longish trip on a tire with a nail in it.
I started typing an email to Justin but I'm just too mad. I can see what they did--they stripped out the plastic hex key that Rays sent with the lugs and switched to a steel hex wrench. The reason Rays sends out the plastic one is because aluminum is softer than steel and will easily strip it out.
I was mad when I ruined my first set of aluminum lugs because I was dumb like that but an alignment shop that works on nice cars all the time? They should have known better.
Old 07-31-2010   #1258
Re: Evo X upgrades
WTF, Sounds like Stellar, isn't so stellar.
Old 07-31-2010   #1259
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I'm a guy that tends to give people the benefit of the doubt for a long time but so far:
1) Lip scratches on two of my wheels. They are light scratches but they weren't there before I brought them in. It's hard to be sure where these things come from so I didn't say anything.
2) Left the adhesive from the old wheel weights on the rim. Not a felony but it struck me as lazy.
3) Now the problem with the lug inserts. I'll probably end up removing them all and running without them. That feature is unique to the Rays Formula lugs but it gave a nice, clean look.
Old 07-31-2010   #1260
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Either these were cross-threaded or the heat from the track day caused the threads to stick? Now I'm not sure which it is.
At Discount Tire can get the new tire on for me on Wednesday. This was the first time that I actually paid for their $100+ road hazard and I'm glad I did. $240/tire!
