Old 09-07-2010   #1441
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Originally Posted by simulatedwood View Post
Confimed NAV works great with the tactrix logging.
I think my NAV problem is more complex. It wasn't working tonight with it disconnected, either. I guess that one remains on the mysteries list.
Old 09-07-2010   #1442
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: Evo X upgrades
Originally Posted by mlomker View Post
I'm going to put a Prosport fuel pressure gauge in that second pod.
Prosport FTW.
Speaking of, I still need to get mine installed.
Originally Posted by Trogdor
Old 09-08-2010   #1443
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Fuel pressure or other gauges?
I threw a couple CELs on the way to work. The 'front o2 slow' that I've seen plenty of lately and rear o2 'no activity'. I've been getting the latter since I had the car tuned. Shot Shane an email to see if the rear was disabled for some reason.
I may need to roll back to the old tune and AMS intake.
After seeing the gooey stuff on the end of my injectors last night, I'm wondering if my hard lines might be obstructed somehow. I don't suppose it'd cost too much to run new lines direct to the engine bay.
Old 09-08-2010   #1444
Re: Evo X upgrades
The gooey stuff is somewhat common for running e85. I ran for over a year once without checking them and one clogged it had so much junk on it. A minute or two in an ounce of gasoline clears it right up.
I'm guessing the rear o2 is disabled since it's only for emissions, but it shouldn't be throwing any rear o2 codes if that is the case.
Good luck figuring things out.
Old 09-08-2010   #1445
Re: Evo X upgrades
Or just a bottle of fuel system cleaner?
Old 09-08-2010   #1446
Re: Evo X upgrades
AKA a gallon of gasoline mixed in for a bit to flush out the junk.
Old 09-08-2010   #1447
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Wasn't sure if that was safe with E85. People also prattle on about E85 keeping everything nice and clean. Umm, no.
The Bosch is moving a lot less fuel than it should be. Running new lines would probably cost the same as two more hours of failed tuning. Of course it's shooting in the dark, like always.
Pump gas mixed in with the E85? Does it have cleaning agents that E85 doesn't have?
Old 09-08-2010   #1448
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
My understanding is that if you disable it and don't physically remove it then it'll get damaged (we didn't remove it). The X will also continue to throw codes unless you wire in a wideband like scheides has done.
Old 09-08-2010   #1449
Re: Evo X upgrades
Alcohol can't dissolve that gooey junk like gasoline does. Soak the tips in 1/2" gasoline in a little cup and the gas will turn black absorbing it all in a couple minutes. There was a big study on this on link awhile back, I can't remember if they determined the source of the black goo that the alcohol can't absorb or not.
Old 09-08-2010   #1450
Re: Evo X upgrades
Mine is disabled and removed from the car completely w/o a wideband and I get no codes.
Old 09-08-2010   #1451
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
SSDD. Another unique issue for me.
I'll do that the next time they are out.
Old 09-08-2010   #1452
Re: Evo X upgrades
2010 vs 2008. Turning off rear O2 stuff is not as easy with the 2008s.
Old 09-08-2010   #1453
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Shane theorized that my oil burning was fouling out the front o2 and causing my problem at cruise. He created a ROM for me that runs in open loop as a test. I went for a short drive and the car ran absolutely awesome. I'll see how it does on tomorrow's commute.
Old 09-08-2010   #1454
mdost03
Sonic Champion!
Drives: VA STI
Re: Evo X upgrades
Awesome, glad you are getting somewhere finally.
I think 311evo's car had some o2 sensor problems as well and Shane made a tune similar to your's that only ran it in Open Loop and it ran perfectly afterwards and even got better mileage than he was getting when he used the o2 sensors.
Old 09-08-2010   #1455
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I didn't know that! Thanks for the info.
The important thing to me is that I've eliminated the custom Primo intake as being a problem. It's a huge plus when you can isolate something.
Old 09-10-2010   #1456
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I've done a number of pulls in the last day to baseline the AFRs before isntalling the afpr and trying the BAP again over the weekened.
I must say, driving that car is like a drug. The only time the cams really lope is right after a hard run...for a few seconds it sounds like Matt D's car. God, I LOVE THAT.
Hope the car is running well for BIR on the 20th.
Old 09-10-2010   #1457
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I received the Prosport fuel pressure gauge, DW1300 injectors, and Magnus master cylinder today. My goals for this weekend are to plumb in the afpr and wire in the gauge. The Magnus will permanently go on the shelf "just in case" and the injectors may be returned or resold pending my next visit to DB.
Old 09-10-2010   #1458
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Apparently I FAIL at putting connectors on -6an fuel line. It leaked and the line was too short by the time I found a technique to do it correctly. I ordered some more line so I'll give it another try on Monday night.
I got lucky and picked a setting that made my cruise AFRs perfect. If it weren't for the leak then I'd be thrilled. The setup was looking very nice other than that.
Old 09-11-2010   #1459
Rmondoh
Minority of MitsuStyle
Rmondoh's Avatar
Drives: '08 OBP Evo X GSR SSS (Deadmau5X)
Send a message via AIM to Rmondoh Send a message via MSN to Rmondoh Send a message via Yahoo to Rmondoh
Re: Evo X upgrades
Glad to see that things are progressing nicely.
08 Evo X GSR - Octane Blue Pearl
Cobb Stg1 AMS 93 OTS: 305hp 291tq 20.6psi
Cobb Stg1 93 Pro: 317hp 322tq 24.5psi
Cobb Stg2 AMS 93 OTS: 315hp 323tq 23psi (LWG map)
Cobb Stg2 93 Pro: 343hp 358tq 26psi
Cobb Stg2 93 Pro: 355hp 361tq 26.4psi (ported stuff)
Rmondoh is offline   Reply With Quote
Old 09-12-2010   #1460
Re: Evo X upgrades
That Magnus clutch master cylinder is the best one on the market IMO. The SSP sounds like a total pile of junk...plus it's more expensive.
