Old 03-22-2011   #1741
311evo
311evo's Avatar
Re: Evo X upgrades
Originally Posted by mlomker View Post
I appreciate you being kind.
Not sure if serious, but if I came off as being a douche I wasn't trying.
Old 03-22-2011   #1742
Re: Evo X upgrades
Those compression numbers are definitely discouraging. Have you done a leakdown test?
Old 03-22-2011   #1743
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Not at all. I made a bad decision but I didn't have enough information at the time.
No, partly due to the symptoms and partly because it was a brand-new head. MAP built it up from a new Mitsu core. The car has been blowing dipsticks, fouling front O2s and filling catch cans with blow-by since a few weeks after the build. I know that head issues can lower compression but could it be the cause of all the oil burning and other symptoms?
Old 03-23-2011   #1744
Re: Evo X upgrades
That sucks. I messed up about three or four engines learning how to do it right. It's been in and out of the car at least six times, maybe seven, but that's moddin' cars for ya. You'll be really good at pulling the motor after the 3rd time. I can have mine out in an hour if I bust my ass.
I like the idea of pulling it apart, honing and new rings, then steady state WOT on the dyno for the first 10 minutes, and engine braking from 150mph to 10mph for the next 10 minutes.
Old 04-09-2011   #1745
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I had another great car day! Spent it with simulatedwood in Hastings
I started by changing all the fluids: motor oil, tranny, tcase, and rear diff. I went with the Redline cocktail for the tranny.
We then did the rear brakes. Girodisc one piece rotors, Carbotech XP8 pads, and Technafit stainless lines.
A little Motiv bleeding action, with ATE Super Blue.
Up front are Girodisc two-piece rotors, Carbotech XP10 pads, but the Technafit lines for the front didn't fit right in the brackets.
Rather than dick around, I threw `em out. I'll order up a set of Stoptech front lines since they replace the lines all the way to the caliper.
Old 04-09-2011   #1746
Re: Evo X upgrades
Nice, i was right down there today as well.
Old 04-09-2011   #1747
PlanoEvo
DL OG
PlanoEvo's Avatar
Drives: Evo IX SE
Re: Evo X upgrades
looking good!
Actually, i lied, hang around the drinking league if you want to party hard.
PlanoEvo is offline   Reply With Quote
Old 04-10-2011   #1748
Re: Evo X upgrades
Very nice! Technafit's customer service is great, you should at least send them back for a refund...or replaced with the correctly made lines.
Old 04-10-2011   #1749
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
The Technafit kit is a poor design. It comes with front & rear lines for cheap ($80 or so) but the front lines only go from car to bracket and use stock lines from bracket to caliper. Once they didn't fit...I threw them away. I wasn't going to remove the rear lines since they were already installed and Shawn's time was limited.
I bought the lines like a year ago based on recommendations...I didn't realize the limitation when I bought them. I ordered a set of the Stoptech front lines this morning ($90).
Old 04-10-2011   #1750
Re: Evo X upgrades
Gotcha.
Be sure to periodically check for fitment/rubbing issues no matter what brand of SS brake lines you have; mine moved slowly over time and ended up rubbing and eventually blew out on the highway during a hard stop coming down from 80.
Old 04-10-2011   #1751
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Will do. Was planning on total fluid changes every 15k miles (once per year for me) since the car is more of a toy than a driver.
Old 04-14-2011   #1752
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Wow, getting my NAV unit working has been a saga. First visit they order an antenna. Second visit the antenna didn't help. Third visit they try two different head units.
Turns out that the tech on the second visit installed the GPS antenna (clips on from the underside of the dash) upside down. bwahaha!
The guys a White Bear Lake Mitsu are super-nice and friendly so I'll give them a pass. Six freakin' hours sitting in their lobby for all of this, though. Could you imagine if I had a serious problem?
I'm happy that my clock is no longer stuck at 4:00.
Old 04-14-2011   #1753
Re: Evo X upgrades
Why didnt you just drop it off? lol
Old 04-14-2011   #1754
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
For two hours at a time? Finding someone with a car to drop me off wouldn't be worth my while.
As an aside, do you ever have anything helpful to say? You're mostly a prick from what I can tell.
Old 04-14-2011   #1755
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: Evo X upgrades
I never leave my car either...
Gotta keep an eye on those squirrely bastards.
Old 04-14-2011   #1756
Re: Evo X upgrades
Wow. Noted, we dont get along. Simple question, didnt realize it was for 2 hours at a time, but thats cool.
Old 04-14-2011   #1757
Re: Evo X upgrades
Isn't this warranty work? Why couldn't they just keep it for a day or two and work on it straight?
Old 04-14-2011   #1758
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: Evo X upgrades
Because it's Mitsu, plain and simple.
Quite frankly, I'm surprised it's getting warrantied at all, considering it's electrical work and the gauges he's got installed.
Originally Posted by Trogdor
Old 04-14-2011   #1759
Re: Evo X upgrades
^Your dealings with mitsu have been bad I take it?
I thought u meant 6hrs straight as well. Either way I don't have patience for that, i hate waiting 30-40 mins for a damn oil change.
Old 04-14-2011   #1760
Re: Evo X upgrades
Mitsu warranty work is only as bad (or good) as the dealer...glad you found a dealer in MN willing to work with you!
