Build the X 17 56.67%
Old 09-23-2011   #1741
PlanoEvo
DL OG
PlanoEvo's Avatar
Drives: Evo IX SE
Glad to hear you got the oil leak fixed. Awesome numbers! Can you post up a boost plot. Would also like to see an overlay of scheides vs your current.
Actually, i lied, hang around the drinking league if you want to party hard.
PlanoEvo is offline   Reply With Quote
Old 09-23-2011   #1742
NICE! So, game on for dyno day then?
Old 09-23-2011   #1743
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
I posted my boost plot already.
Old 09-23-2011   #1744
Murlo26
Murlo26's Avatar
Maybe, but doubtful. Shane said he needs another two hours with it. So prolly won't happen until Monday. I'll let ya know though.
Old 09-23-2011   #1745
Go back a page, they're both posted.
Old 09-23-2011   #1746
To add to my overlay of our cars earlier:
My car peaks at 32psi, yours just barely touches 31.
So your car makes more torque down low with less boost and almost the same power midrange and up top with less boost! I'm impressed with your setup man--leave it and drive it!
Old 09-23-2011   #1747
I'm impressed with the EF3 and EF4 so far! Maybe i should have tested the EF2...damn it
Old 09-23-2011   #1748
This thing should be ready to rock for the cruise then eh?
Old 09-26-2011   #1749
Murlo26
Murlo26's Avatar
Got the car back tonight! It scared me when I went WOT, a great sign
The open dump is pretty loud, lol, but its not too terrible imo, we will see if I get sick of it.
Here are the final graphs.
Yay!!!
Old 09-26-2011   #1750
dayum...
Old 09-26-2011   #1751
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
nice power on lower boost.
Just glad to see it running again.
Old 09-26-2011   #1752
Murlo26
Murlo26's Avatar
Thanks and yes I am glad it runs again as well, thats all I really want at this point, lol.
Old 09-26-2011   #1753
Good god, epic! Just curious, what's WGDC at through the upper midrange and way up top? Any more boost left in it? Seems low but then I remember you have that extra .2L to make more power at less boost with :P
Fukin sweet powerband, looks SO strong up top! My car peaks around 7000-7200 and falls off ~30whp by the time it gets to 8300rpm, yours is preeetty damn flat from 6800-8500! Insane!
Remind me, are you still on the stock IM/TB?
Old 09-27-2011   #1754
Also, what IDC are you peaking at?
Old 09-27-2011   #1755
Murlo26
Murlo26's Avatar
I attached a log for you. It's one I took today on the way home from DB on a 3rd gear pull after filling up with gas.
We were not maxing it out, I didn't want to push it anymore than we already did. The actuator was supposed to be a 1.7 bar one (roughly 24psi) but only held 19psi tapering to 16psi on wastegate boost so I think with a stronger spring it would hold more up top.
Yes, I am on stock IM/TB. Those are really the only future upgrades I have for power aside from t3 kit which will happen if I ever get bored.
Old 09-27-2011   #1756
Murlo26
Murlo26's Avatar
Not sure on this one.
You have to enter scaling into evoscan to log this right? I have never logged IDC.
Old 09-27-2011   #1757
Holy crap, just looked at your logs. Timing is super conservative....then again you have higher compression so I guess that could skew my perception of what is acceptable. Tune looks very nice though.
IDC peaks at 91.9% @ 8000rpm.
WGDC is not maxed, so you probably have a bit more left in it.
You need to wire your wideband into your ecu.
You need to rip this until next year, perfect DD setup. Log it periodically, have some fun with it!
Old 09-27-2011   #1758
Murlo26
Murlo26's Avatar
Shane said yes it is conservative but he also said what you did, that with the higher compression this could be just "normal" for timing.
The log only goes out to 8000rpm on this pull and we tuned to 8800 and up there I think wgdc is maxed but I could be wrong.
Shane asked about the wideband already as well as he wants to see some transitional stuff on the road in between gears, he thinks I could be running a bit rich. I have my AEM wideband, I was planning to work on it this weekend and see if I can get it wired in.
Overall, I think the tune is a tad rich, tad low on boost and a little conservative on timing, basically exactly what I wanted
I am sure another 30whp could be had and quite a bit more torque with more boost and what not but for now I am happy.
Old 09-27-2011   #1759
Tachyon
Tachyon's Avatar
Drives: Icarus
Looks good, Dave. I was up at DB yesterday when the final pulls were being done, sounds nice!
-Sebastian Vettel
Old 09-27-2011   #1760
Murlo26
Murlo26's Avatar
Thanks bud!
On the dyno it just seemed loud and I thought sounded great, on the street the open dump seemed a little raspier and still loud.
I don't hate it by any means but it will take getting used to it.
It is only at WOT so its not so bad at all, but damn, its loud lol.
Tags
