Old 10-17-2011   #21
Sparky2211
Sparky2211's Avatar
Drives: 2g DSM, 2008 Evo X
Re: 97 GSX/ Borg s259 ett/ e73 dyno results
Very impressive numbers! I love the powerband!
1997 Eclipse GSX - Project car - 601hp/475tq
2008 Evo X GSR SSS - Daily Driver - 407hp/434tq
Sparky2211 is offline   Reply With Quote
Old 10-17-2011   #22
Overlay shows mara's SC61 outspooling this thing but the BW turbo kicks butt up top!
The bad topend on Mara's SC61 had to do with the intake pipe in front of the turbo. This is after fixing the intake problem and some other changes( http://www.mitsustyle.com/forums/att...2&d=1285892300 ), but a better comparison of the turbo potential, it wasn't the SC61s fault for the old bad powerband.
His divided T4 housing should help spoolup a decent amount, but his exhaust manifold runners are on the big side and his cam has no low end, so those are probably hurting his spool up. You can have the same turbo on the same size motor spool 1500 RPMs different from one car to another depending on things like exhaust manifold, cams, intake manifold, cam gear settings, fuel used, etc.
His clutch slipped bad enough for the RPMs to shoot to revlimiter a couple times, so we had to keep the boost/power down some.
Old 10-17-2011   #23
hmm that SC61 looks so good.
Old 10-17-2011   #24
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
Thanks for the info Shane and again thanks on the killer tune. I may swap the cams out for some kelford 272's and see if I can pull some vacuum/gain some spool time. Next time the clutch should be broke in so we can push the turbo to it's limits!!! And I don't feel that the spool is too bad considering it pulls so hard all the way to 9k without peeling off.
If you can't afford to buy an EVO, might as well beat an EVO
Boomdeeze is offline   Reply With Quote
Old 10-18-2011   #25
Very nice numbers for a 59mm turbo! Better clutch and more boost, and you should be in the 500's!
Old 10-18-2011   #26
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
Well the clutch is a South Bend SS-OFE Stage 4 so I just think it needs to be broke in along with the flywheel. Then the psi will increase so so will the awhp.
Old 10-19-2011   #27
An overlay of Shane's fixed setup, and this would be cool. These are about the kind of numbers I was hoping for with my old 1g.
