View Poll Results: How much WHP will I make on Cobb's AWD Mustang dyno?
<450 2 11.11%
450-475 3 16.67%
475-500 6 33.33%
500-525 3 16.67%
525-550 3 16.67%
>550 1 5.56%
Voters: 18. You may not vote on this poll
Old 03-20-2012   #201
Re: SE take two!
I drove my X up once for a DB tune before going to Cobb, but Andrew hasn't gotten a tune anywhere yet. I always used to have DB tune my IX, but that's when I lived in MN.
Old 03-20-2012   #202
Revobasher
Revobasher's Avatar
Drives: 14 Evo X GSR
Re: SE take two!
So even would a bad tune isn't a bit surprising one of these Howard rods would snap and at that power level?
2014 CB Evo X GSR - 323/324 @ 26lbs (Mustang Dyno)
2012 IS250 F Sport - TOTALLED
2006 Evo IX MR - ​SOLD
Revobasher is offline   Reply With Quote
Old 03-20-2012   #203
Re: SE take two!
With a bad tune it's not about power, it's about cylinder pressure. High compression pistons + a lot of boost + too much timing + E85 is a dangerous combination for an inexperienced tuner.
Old 03-20-2012   #204
Revobasher
Revobasher's Avatar
Re: SE take two!
Gotcha... thanks for clarifying.
Old 03-20-2012   #205
Zivman
Drives: IX @ 33 psi
Re: SE take two!
gotcha...
Zivman is offline   Reply With Quote
Old 03-20-2012   #206
Zivman
Drives: IX @ 33 psi
Re: SE take two!
with a f^cked up tune anything is possible. it can blow the best of components apart
Old 03-20-2012   #207
Revobasher
Revobasher's Avatar
Re: SE take two!
yeah.. I wasn't pointing fingers.. just was surprised as I believe Chris had mentioned this is the first of these rods to EVER fail.
Old 03-20-2012   #208
Re: SE take two!
First to ever completely snap, they did have a rod bend north of 1000whp once.
Old 03-20-2012   #209
Re: SE take two!
Steve hills Evo had a bent olivers as well.
Old 03-25-2012   #210
PlanoEvo
DL OG
PlanoEvo's Avatar
Drives: Evo IX SE
Re: SE take two!
Got some good work done this weekend the head came off and to be expected some damage at least 3 bent valves in #3 and some combustion chamber stuff too. I've sent the EF3 back to MAP in the process of becoming an EF4 and I will shipping the Head back to MAP as well for some MAP TLC. Sould have the engine out next weekend and start putting it back together as soon as the head comes back then a mad rush to get it ready to drive up for the Spring Cruise can i get a Hell Yeah!!!!
Actually, i lied, hang around the drinking league if you want to party hard.
PlanoEvo is offline   Reply With Quote
Old 03-25-2012   #211
PlanoEvo
DL OG
PlanoEvo's Avatar
Drives: Evo IX SE
Re: SE take two!
Damn I'm getting good at this....
Car in repair
Hole front side
Hole back side
Pistons
Fucked #3 piston
Head and Intake manifold
Old 03-26-2012   #212
Re: SE take two!
Owie!!
Old 03-26-2012   #213
Re: SE take two!
Any damage to the transfer case this time?
Old 03-26-2012   #214
Re: SE take two!
ouch
Old 04-07-2012   #215
PlanoEvo
DL OG
PlanoEvo's Avatar
Drives: Evo IX SE
Re: SE take two!
Turbo looks close to being done...words out on the the head as damage to the combustion chamber occurred waiting to hear back from MAP as they are doing their best to salvage it... also >9o% chance its not going to be ready for the cruise
Old 04-07-2012   #216
Re: SE take two!
BOOOOOOO
Old 04-07-2012   #217
PlanoEvo
DL OG
PlanoEvo's Avatar
Drives: Evo IX SE
Re: SE take two!
BOOOOOOO
Unless a miracle happens in the turbo and head come back asap and a host of other unlikely things happen....
Old 04-07-2012   #218
PlanoEvo
DL OG
PlanoEvo's Avatar
Drives: Evo IX SE
Re: SE take two!
Nope all good this time :-)
Old 04-07-2012   #219
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Re: SE take two!
that sucks man, well good luck getting this biotch back on the road asap
2006 WW IX RS 396/404 - SOLD
Old 04-07-2012   #220
Re: SE take two!
I have a hoist you can borrow! It's in plymouth....
Tags
post liked by shane
