View Poll Results: How much WHP will I make on Cobb's AWD Mustang dyno?
<450 2 11.11%
450-475 3 16.67%
475-500 6 33.33%
500-525 3 16.67%
525-550 3 16.67%
>550 1 5.56%
Voters: 18. You may not vote on this poll
Old 02-28-2011   #1
PlanoEvo
DL OG
PlanoEvo's Avatar
Drives: Evo IX SE
SE take two! Err, make that three!
Well where do I start lets see late last summer after finally getting my car running well on e85 went to over to Kracka house for some cold drinks. Took the car out for a spin one hard pull then a 1/2 throttle onramp and boom! Mods at that time were TB exhaust FP 4R cams intake and manual boost at 34psi...Fast forward to recently to start the rebirth.
New parts
Map 2.3L stage 2 BS removal 10.5:1 CR
Map stage 3 head
milspec intake manifold+65mm TB
Megan O2 housing SPCoatings
Scheides old ex manifold SPCoatings
Map EF3 turbo stock compressor cover,PPI ported,SPCoatings
DW fuel pump+1450's
Cobb downpipe
Map beehive springs
PPI upper IC pipe
Works flywheel + CM FX400+Rosie clutch stop
MAP HP wastegate actuator
Actually, i lied, hang around the drinking league if you want to party hard.
PlanoEvo is offline   Reply With Quote
Tags
post liked by shane
