Old 04-23-2012   #81
Re: Lucky #13...Back in the saddle....92 rt/tt
Updated parts list completely installed on car:
Quadco Output shaft spool
E2K t-case brace
Stainless clutch line from STM (master to slave)
Deautchwerks 1000cc Injectors
Deautchwerks 301 fuel pump
"Maximal Performance" Solid Motor Mounts
Fuel Lab "mini" regulator with gauge
5 bar Map sensor
GM AIT
E-bay 3" downpipe (non "F" style)
Rear 02 eliminator (e-bay)
AEM dual channel wideband controller with new widebands
New dash vents (cracked ones drive me nuts)
8mm NGK plug wires
NGK 4554 plugs
Russell AN6 Black Fuel filter
Teflon AN6 lines in engine bay and at tank
Aluminum shifter base bushings
Alpine Type S 6x9 rear speakers
2-5/8" Black face, Silver Ring Stewart Warner Performance Gauges:Oil pressure, Water Temp, Vac/Boost
Shifter bushings
"Seattle" bearing short shifter
Top to bottom intercooler (25x6x3.5" core, 1453cfm, 3" outlet, twin 2.5" inlets)
Mitsubishi Evo 9 BOV
2.25" Intercooler piping
3" Intercooler piping - Cold Side
3" Intakes
Oil Catch Can
GVR4 coolant overflow -just need a overflow cap
BigCranks mini battery
In process now-Slated for completion:
AEM EMS V1 (used/rebuilt) - to AEM to be fixed
Pioneer 6.5" TS-G1643R door speakers -install
Short antenna-install
Oil temp sender for SW Oil Temp Gauge - waiting on adapter for oil drain, gauge installed
On the list for this summer/after this round:
Fabricate cat-back exhaust
Stronger Clutch
Ethanol Content Monitor/Display
Larger turbos?
New tires
Update:
Got the bumper on last night with ducting modified to get around the FMIC, hopefully I won't be overheating. Just need to clamp the "catback" exhaust to the adapter John made and bolt that to the downpipe and that is done. Need to toss in the short antenna (well don't need to but want to) and pick up a drain plug or two and install the oil temp sensor sender...or just wait for the right parts to get here and install next time, I will probably go that route.
AEM is scheduled to arrive Tuesday.
Old 04-23-2012   #82
Nice!
See you May5 @ DB?
Old 04-23-2012   #83
Future plans:
This is a GT car and will remain a GT car. Plans are to keep it on TD04's. Running E-85 and keeping the budget low, the goal is to get into the 11's, while maintaining creature comforts, all while using E-85.
Pictures at first purchase:
Looks like your future plans have changed. haha.
Old 04-23-2012   #84
Nice!
See you May5 @ DB?
Maybe.
Yes/No. Still trying for 11's, we'll see how the car responds to boost/tuning.
A/C - Check
Full Interior - Check
Street suspension - Check
Stereo - Check
So far I've managed not to compromise anything, just tried to replace failing parts or weak links with upgrades I see fit. One day I am sure I will end up on an all forged engine, but for the most part I am 95% certain I will stay with bolt-on turbo's.
Old 04-27-2012   #85
E2K t-case brace
5 bar Map sensor
GM AIT
8mm NGK plug wires
NGK 4554 plugs
Shifter bushings
3" Intakes
Oil Catch Can
Short antenna
Rear 02 sensor (O2 #1)
On the list for this summer or later:
Stronger Clutch
Larger turbos?
New tires
Evo 8 Wheels
Secret sauce TD04's
Update:
Car lives. I had one 02 sensor show up DOA, so overall not to shabby. Now to drive it and tune it off the front bank. I won't switch over to E-85 until my failsafe pump gas map is done (work in progress), and my rear 02 sensor is back in house.
Car is LOUD without mufflers. I will have to bump up priority on that cat-back. Another strange oddity: I cannot mount my front plate. I have now received 2 front plate brackets, neither fit.
Name:	Stealth Spring Build 2012 Assembled.jpg
ID:	12463   Click image for larger version
Name:	Stealth Spring Build 2012 Assembled (6).jpg
Old 04-27-2012   #86
Lookin good!
Old 04-27-2012   #87
Very nice, i like that CF piece.
Old 04-27-2012   #88
I have one of those ethanol monitors if you want I'd sell it to you. Don't have the sensor though.
Old 04-27-2012   #89
One of the Zietronix ones?
Old 04-27-2012   #90
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Coming along nicely sir!
Old 04-27-2012   #91
One of the ones that someone on here designed and sold a few years ago.
Old 04-29-2012   #92
Well this weekend was productive:
Figured out my DOA wideband sensor is actually controller or wiring related, so I need to find time to dig into that, just using the front bank for now.
Figured out my Idle Air Control motor is dead, new one on the way.
Then proceeded to setup a 92 octane fail safe map. I used the full tank of gas in there from October, and the tank was open for a month or two....so in reality it is probably an 85 octane tune, but it will get me by if I need gas to get to the next E85 fill up location.
Then proceeded to tune on E-85 and hit a minor hiccup. The stock clutch is NOT happy any longer, so a replacement is on the way as well.
E-85 results below with a slipping clutch. I know its slipping as it takes more and more RPM to get the same road speed, and the AFR was changing. Hard to know the exact amount of slip, but I will find out.
Don't worry about the peak numbers but the curves are nice!
21psi spike, 16psi hold.
Old 04-30-2012   #93
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Not too shabby
2006 WW IX RS 396/404 - SOLD
Old 05-04-2012   #94
Graphed the rpm versus mph...yeah it is slipping under projected peak torque (3500) and just continues to slip more and more as rpm increases. Makes sense as the factory clutch is rated to 300whp and I would anticipate this car to be right around there.
So...my 6 puck XTD disc should be here today, which is good as I have a southbend pressure plate waiting for it.
Old 05-04-2012   #95
Nice.
Old 05-04-2012   #96
XTD disc!!! I have one of those cheap suckers in the Lexus too lol
Old 05-04-2012   #97
The pucked clutches seem to have great reviews.
Old 05-07-2012   #98
Quick update, Had an extra flywheel here, dowel pin snapped off in it . So I ordered a stock style replacement as I would imagine the flywheel in the car has more hot spots than the surface of the sun.
Clutch is slipping still but added some timing up top, car now holds 300+hp per virtual dyno to redline Can't wait to get the 6 puck in and rent some dyno time at MAP after I break in the clutch.
Also ordered a new throw out bearing as the one that was available cannot be found. Goal is to get the clutch in Friday night/Saturday and then start breaking it in. Finish up street tuning and rent an hour of dyno time sometime before proving grounds. Hope to have the tires on by then as well (should) and we'll see how deep into the 14's I can get
Blue graph is more timing compared to image in post #92, red graph is more timing yet. Problem is with additional timing comes more and more RPM needed to achieve the same MPH so I need to stop and wait for the clutch Good amount of slip noted before 4k and after 5500rpm, power curves and AFR move to back that up . The red pull was just a quick check and I hit it pretty late, thus the lazy boost response, just wanted to check the cells "up top". Like I said, nearly time to break in the new clutch after install and see what it does on the real dyno!
Old 05-07-2012   #99
cman3000
Colin
cman3000's Avatar
100m Running Champion!
I was planning on going with one of those XTD 6 pucks as well when I was going to do 15gs, they really do have awesome reviews for how cheap they are. I ended up going with a Competition Clutch Stage 2 to get my VR4 back on the road. Not too many reviews on them, but the few people that have them seem to like them a lot.
cman3000 is offline   Reply With Quote
Old 05-10-2012   #100
Update:
Pulled transmission tonight, found a Napa special clutch (LUK). Looks like flywheel step was off (to high) and the clutch was slipping. Shame as it is fairly new looking....looks like it will be part of a scrap run now.
Also picked up a HKS BOV (Thanks John) to replace the leaking EVO VIII BOV. Haven't tested it, but if it holds more than 19psi I am golden as that is when the current BOV started to leak. Figure that plus clutch means I can maybe get 24spike out of the 9b's and maybe 17 to redline? We'll see after break-in.
