Old 09-14-2011   #1
Lucky #13...Back in the saddle....92 rt/tt
Vehicle: 1992 Dodge Stealth RT/TT
Purchase date: 9/7/11
Modifications at purchase:
K&N drop in filter
Dual head unit
Active exhaust (mufflers) and main cat delete
"Free boost" mod
Modifications added before Winter 2011:
EVO BOV
Y-pipe stay bracket
Changed oil to good old Rotella T
Vacuum line delete
Boost Gauge
Manual Boost Controller
EGR Delete
Engine bay clean-up
Amsoil in transmission/t-case/rear end
25 spline output shaft replaced + 300M spool + E2k T-case brace
Future plans:
This is a GT car and will remain a GT car. Plans are to keep it on TD04's. Running E-85 and keeping the budget low, the goal is to get into the 11's, while maintaining creature comforts, all while using E-85.
Pictures at first purchase:
ID:	11990   Click image for larger version
Old 09-15-2011   #2
Re: Lucky #13...Back in the saddle....92 rt/tt
Douche. Reserved for serious comment later.
Old 09-15-2011   #3
Revobasher
Revobasher's Avatar
Drives: 14 Evo X GSR
2014 CB Evo X GSR - 323/324 @ 26lbs (Mustang Dyno)
2012 IS250 F Sport - TOTALLED
2006 Evo IX MR - ​SOLD
Revobasher is offline   Reply With Quote
Old 09-15-2011   #4
Or you could start a thread when there's something to post..................
Old 09-15-2011   #5
Tachyon
Tachyon's Avatar
Drives: Icarus
Maybe he was afraid somebody else was going to create a thread with the exact same name?
-Sebastian Vettel
Old 09-15-2011   #6
I had this 1/2 way completed last night, then went to bed and shut off my computer . First post updated
Most recent picture with decals pulled, legal rear tail lights, and working window regulators:
Old 09-15-2011   #7
Does it still have the stripe on the side. I think i saw you yesterday on 169.
Old 09-15-2011   #8
Wasn't me as the car has been in my garage now, having crap ripped out of it, for about 30 hours now. Last time I drove it was Tuesday night.
Must be a clone.
Old 09-15-2011   #9
Very nice! KISS.
Old 09-15-2011   #10
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Looks pretty clean. I like the plans to keep the creature comforts and streetability. Good luck
11.35 @ 120mph
Old 09-15-2011   #11
Very nice! KISS.
Awww.... Scheides and Swanny Sittin in a tree... K.I.S.S.I.N.G. First comes love, then comes marriage, then comes the baby in the baby carriage.
Old 09-15-2011   #12
Good to see you planning on keeping this a street car.
11s will be easy, i can't wait to see it on 13Ts. Good luck.
Old 09-15-2011   #13
This is a GT car and will remain a GT car. Plans are to keep it on TD04's, first the stock 9b's, then probably 13T's (WRX TD04L hybrid setup). Running E-85 and keeping the budget low, the goal is to get into the 11's, while maintaining creature comforts, all while using E-85.
Very similar goals as me, oh how we grow up... Sounds like a perfect plan for that car!
Old 09-15-2011   #14
11s will be easy. Good luck.
Old 09-15-2011   #15
I don't know about easy but I think do-able eventually. Unless money falls out of the money tree the car will be on evo injectors, s-afcII, FPR, fuel pump, E-85 for this spring to see how deep in the 12's I can get.
True true. The purpose built race car to drive on the street days are over!
Very nice! KISS.
K.I.S.S is a good motto when you want to enjoy the car instead of re-invent the wheel.
It should only need about 460awhp to get there.
Old 09-15-2011   #16
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
looks way better without the stickers. lol. looks cleeeean. I've always wanted a 3/S...they just seem hard to put in turbo's
ლ(ಠ益ಠლ)
Old 09-15-2011   #17
looks so much better with out the stickers
Old 09-16-2011   #18
Only being the key word. 460 is a lot to make, then you need to get it to the ground. I just thought it was funny saying that 11's are easy.
Old 09-16-2011   #19
You have a good point. The 460 is on a dynojet and full weight. A good powerband may drop that down a bit. I know Ryan's went 11.4@120 with 420hp/460tq, granted that had custom gears and was lighter. If it was full weight and didn't have the gearing, I would have anticipated that car to go ~11.9.
Only time will tell. After this weekend, assuming good engine health, car should be low 13's.
I agree that 11's aren't easy, in anything.
Old 09-16-2011   #20
Small update:
Did a boost leak test....... ....20psi in, 2psi at the gauge (hooked up my diagnostic 52mm autometer to the plenum).
Started poking around, rear o-ring and 1/2 the vacuum lines leaking like a zepplin with a bullet hole in it. Excellent opportunity to do the vacuum reduction mod/clutch booster delete mod.
I decided I should change the drivetrain fluids to see if I can catch the "zip" into 2nd gear before it gets worse. Staring at the transfercase, it has the bolt in the cover (YES! )
Decide I should drop the t-case to look at the transmission to see if it has a 25 spline, being a Dec 1991 build date, there is a chance.
It is a 25 spline! (YES! )
The shaft is rusted to where the splines are like a butter knife (NO!! )
Good thing Ryan has a few parts left from his part-out. I will be introducing a new output shaft, t-case with quadco spool, and E2K brace this weekend, with new fluid, MBC, throwing a boost gauge in the glove box for now, vacuum reduction, and then leaving it alone until winter
Car has pre-cats still, leaving those in as those are my effective "mufflers" for now. I will toss on exhaust this winter and then gut those.
Before spring 2012 goals:
-Gauges in center dash
-Wideband
-Replace dash vents
-Re-cover seats (driver side has tear)
-upgrade fuel pump
-fuel pressure regulator
-fuel controller + logger
-injectors
-Exhaust
-E-85
-Good non knock-off tires
