Old 09-05-2012   #101
Re: 1g 6 bolt 4g63 tsi build
Yep, get the solid ones for evos, they fit dsms too and are a good upgrade.
Old 09-06-2012   #102
Not the carrier bearings but the actual mounts that connect the chassis to the strap thats on the carrier bearings. Nice improvement when done with rear diff mount bushings as well.
Eff this car is looking good!
Old 09-06-2012   #103
dsmghost
dsmghost's Avatar
Drives: 1gb Talon TSi AWD
Ill do both the carrier bearings, all the u-joints, and the strap to chassis mounts. This sloppy rear diff is pissing me off, tons of gear backlash and howls on decel.
Old 09-10-2012   #104
dsmghost
dsmghost's Avatar
I installed a deck I had laying around, I also chopped the stock antenna off and installed this powered amplified antenna on the interior. I got it at Orielly's for $18. It looks way better without the long stock antenna, and works great too.
ID:	12811   Click image for larger version
ID:	12812   Click image for larger version
ID:	12814   Click image for larger version
Old 09-13-2012   #105
dsmghost
dsmghost's Avatar
So today I hit the 1000 mile mark since initial assembly of the Talon, I changed the oil and installed new Bosch Evolution wiper blades. I even got a new one for the rear. Looks like I need a car wash again. I'm also throwing in another pic of the new antenna.
ID:	12825   Click image for larger version
ID:	12826   Click image for larger version
Old 09-13-2012   #106
dsm_talontsi
dsm_talontsi's Avatar
Drives: 91 Eclipse GST
NICE!
dsm_talontsi is offline   Reply With Quote
Old 09-13-2012   #107
dsmghost
dsmghost's Avatar
Yeah they are nice blades, some places charge over $25 per blade. I got them for about $8 each.
Old 09-29-2012   #108
dsmghost
dsmghost's Avatar
Installed the speed density setup, I still need to hide the wiring, and mount the MAP securely to the firewall. Pushit2.0 did a great job welding on the IAT bung for me. With SD the car runs better than it did with the 2g mas. Having another member do some street tuning for me next week.
Also going to be installing my electronic boost control solenoid soon, been pretty lazy though.
ID:	12872   Click image for larger version
Old 09-29-2012   #109
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Originally Posted by dsmghost View Post
Just found this picture, it was a couple weeks ago when I put in a new LF output shaft seal and new transfer case seals.
Reckless DSM'er no jack stands !? Anywhoos getting work done good job!
Old 09-29-2012   #110
dsmghost
dsmghost's Avatar
haha yup, I used to have a set of 4. oh well
Old 10-01-2012   #112
dsmghost
dsmghost's Avatar
Originally Posted by blackrosenova400 View Post
Are you going on the cruise? I hope to be, Im assembling a 2.3 stroker right now.
Unfortunately I wont make it. My gas tank leaks if I fill it over 3/4 tank, and I doubt Ill get a different one in by then.
Old 10-01-2012   #113
dsmghost
dsmghost's Avatar
With the SD setup, I wanted to get rid of the 2g MAS without running filterless. This is what I came up with in a hurry, it will do until I find/make a nicer pre-turbo intake/filter. Looks kindy goofy with that filter idk. I also wanted to keep my BOV recirculated.
ID:	12875   Click image for larger version
Old 10-01-2012   #114
dsmghost
dsmghost's Avatar
Swapped the OE looking tan ISC for a good black ISC today.
Old 10-10-2012   #115
dsmghost
dsmghost's Avatar
Today I installed a Ingersoll Rand boost solenoid from Ecmtuning. The boost control function on Ecmlink is badass! Im still tweaking the base duty cycles, once I get that dialed in well I can enable the error correction feature. Just gotta wait for traffic/rush hour to end so I can make some 3rd/4th gear pulls. Being able to fine tune boost levels throughout the RPM range and in different gears is awesome. And for $45, thats cheaper than any good name brand MBC!
Old 10-10-2012   #116
Gushers
Drives: I push project cars
Nice, I don't know a whole lot about ECMlink, but that sounds like it's the route to go
Gushers is offline   Reply With Quote
Old 10-10-2012   #117
Sweet! That is really cheap. Boost by gear sounds like it could be nice too, more for fwd or higher powered cars, but nice to have regardless
Old 10-31-2012   #118
dsmghost
dsmghost's Avatar
My starter solenoid has been causing an intermittent no start, so I swapped it with a spare starter I had. Also, I've had to add coolant a time or two in the past few weeks, pressure test revealed a small leak on the heater hose, just had to tighten the clamp. Almost 3k miles since assembly, its been a great daily driver except the starter recently acting up.
Since I can get Blizzaks for 50% off store cost and I can mount and balance for free, I'm going to be getting a set soon and hoping for snow. Im going with the LM-60s they have a H speed rating. The WS70 is a T.
Old 10-31-2012   #119
That is badass. Nice work.
Old 10-31-2012   #120
Saw you in traffic the other morning
