View Poll Results: How much WHP will I make on Cobb's AWD Mustang dyno?
<450 2 11.11%
450-475 3 16.67%
475-500 6 33.33%
500-525 3 16.67%
525-550 3 16.67%
>550 1 5.56%
Voters: 18. You may not vote on this poll
Old 03-27-2013   #321
Re: SE take two! Err, make that three!
Safe and consistency are two very different words.
Is E85 safe? Depends.
Is E85 consistent? Definitely not.
The problem isn't the ethanol itself, it's the crap the blenders mix with it to make E85.
Old 03-27-2013   #322
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Different yes, but they can be directly related for sure.
TRUE E85 is awesome, I agree its the crap that gets mixed in that is the problem. But if you buy real E85, or even C85 (c16/e85 mix) then you have some baller ass stuff.
Obviously many many people run it, especially in evos and for the amount of people that use it there are not a ton of failures, especially considering how hard people push it.
Also, I would imagine texas has a lot more consistent e85 than us MN'ers.
Old 03-27-2013   #323
How do I "like" this post?
Old 03-27-2013   #324
Consider it liked!
C85, E98, or E85 from VP Fuels, for example, is an entirely different animal than pumping it from the corner station. Those have controls and consistent quality, the corner station's E85 does not. I can assure you the ethanol that VP uses is of the utmost quality though, and the denaturant is exactly what you want and where you want it (natural gasoline from Conway, KS blended in at 2.2-2.4%)
E85 down here is a double-edged sword, on one hand we have more consistent ethanol blend percentage, but on the other hand the blendstock seems to be worse quality overall. It's this blendstock that causes injectors to get sludgy, and with unknown blendstock, it is very important to run a tank of quality premium gasoline through the system every few weeks.
Old 03-27-2013   #325
93gtpeater
Drives: cbr 1000rr repsol
You could always buy a 55 gallon drum and blend your own e85
Old 03-27-2013   #326
Murlo26
Murlo26's Avatar
To me that takes out the "convenience" of e85 though which is a huge reason I run it.
If I had to do that I would probably opt for a different form of race gas, be it buying e85/c85/e98 by the barrel or c16/ms109 or vp import or something.
once you graduate to the whole barrel for fueling then it becomes a whole new game in my mind. And also at that point, I'd rather have something that didn't require a HUGE fuel system, so I'd opt for race fuel over e85 variants.
Old 03-27-2013   #327
How? Buy a drum of E98? At that point, just run the E98.
Old 03-27-2013   #328
Murlo26
Murlo26's Avatar
Is this toward me? I think I was basically saying this lol.
Old 03-27-2013   #329
93gtpeater
I say stick to pump gas. E85 is great if you can get real e85 all the time. But with how much money you guys got into your cars I say stick with pump gas.
Old 03-27-2013   #330
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
I love E85 havent had one problem...yet lol. Ron does all my tuning, cant go wrong their. I have a Zeitronix ECA for easy monitoring and evoscan for logging some WOT pulls.
2006 WW IX RS 396/404 - SOLD
Old 03-27-2013   #331
Nope, post above yours.
That's what everyone says until they plug an injector and window the block. Play it safe and run a tank of gas through the system every month. I sell the shit for a living, I'm not making this up.
Old 03-27-2013   #332
cmspaz
Walls need hugs too
cmspaz's Avatar
And if not a tank of pump, at the very least an E85 specific cleaner of some sort. Both Lucas and Gumout sell products designed to clean E85 fuel systems.
When my injectors come out this spring we'll see how well the Lucas offering has been doing.
Originally Posted by Trogdor
Old 03-27-2013   #333
^Excellent point. Other fuel additives such as Chevon Techron are also supposed to be compatible with ethanol. The problem is there are just no standards or requirements for E85 like there is pump gasoline.
Old 03-27-2013   #334
Tachyon
Tachyon's Avatar
Drives: Icarus
Hmm, I've gone about 8000 miles on E-fuel since looking at my injectors. Now I am super curious to know what they look like. I'll find out when I swap the heads in a week.
-Sebastian Vettel
Old 03-27-2013   #335
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
I've asked Ron these same questions about the injectors gumming up and he said hes never seen one do that.
Old 03-27-2013   #336
Murlo26
Murlo26's Avatar
I put 10k miles on my dw1300's, they looked perfect when I pulled them.
I guess all of those miles weren't e85, all but maybe 1000 or 1500 were though.
Old 03-27-2013   #337
It all depends on your E85source. The E85 down here is notorious for it; seems hit or miss up there.
Old 03-27-2013   #338
Some local's hit with gunk as long as 4-5 years ago now.
http://mitsustyle.com/forums/showthr...ck+gunk&page=4
Old 03-27-2013   #339
cmspaz
Walls need hugs too
cmspaz's Avatar
Could be a higher quality of local fuel? Somehow I doubt that though. I've seen so many images of the gunk that it's just easier for me to be safe than sorry. It's not a myth, that's for damn sure.
Old 03-27-2013   #340
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Yeah i suppose, maybe later this spring when a few more EF2.5's get tuned and tweaked I'll get a 91 map as well.
Tags
post liked by shane
