Old 08-31-2005   #8
Re: Rebuild time!
You forgot a front cover including new oil pump gears and a timing belt kit with new tensioner. The whole gasket set from Mitsu is $190 and includes turbo gaskets and even the nice 7cm one. And if you've already got the Clevites, they're fine if you debur them, otherwise get the ones others have suggested. The metal hg is nice, but if you're only running 25psi or less, the stock Mitsu that comes in the kit is more than adequate. Everything else looks good.
