Old 10-02-2005   #11
Re: Priming the oil pump and break in ?'s
If you are going to run the factory ECU, get the timing maps in the ECU changed. The stock 1G maps are meant for a 7.8:1 compression motor, going to 8.5:1 can be hard enough with the kind of timing the 1G ECU wants to run.
