Old 11-10-2005   #9
Re: How much boost?
Originally Posted by scheides
but your egt's spike through the roof b/c you're detonating like crazy.
The only reason your EGTs go up on a DSM when you knock/detonate a lot is because the knock sensor/ECU sees it happening and retards the timing a lot. Low timing = High EGTs. With no active knock sensor, it will just continue knock away.
