Old 01-06-2004   #6
LightningGSX
Hellbound
What color wire(s) did you hook the power to? Did you check the ignition fuses(under the hood)? I can't remember but the 95's might have a crank fuse on the inside(in the normal fuse block) too.It is a pretty common problem with Fords and remote starts, to blow one of the main fuses.If you can't figure it out, send me a PM with your number, I can probably figure it out over the phone or if you are reasonably close to St.Paul Park/Cottage Grove, I can come fix it for you.
-Nulli Secundus-
