Old 12-06-2005   #2
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: 90' NT Water Pipe
Get a 90 Turbo water pipe. Either that or weld/cap up the pipe that would normally go to the oil cooler. Thats what I did. I use a 90-94 turbo water pipe and just welded it shut.
You could always cut the return line, one that runs under the turbo to the water pipe and just run a rubber hose from it to the pipe that would normally go to the oil cooler.
Also, what thermostat housing are you using? I assume you are running a 1st gen head? If not it wont work.
Originally Posted by shoutbox
