Old 12-19-2005   #5
Re: Leaking caps, ECU ruined?
I would do a full boost leak test with a pressure gauge right in front of you so you know how much pressure your system is holding. If you have a bad enough leak, you may not even hear it leaking, as the system will not build boost at all. You can make a proper boost leak tester for about $20. I say make one, borrow one, or buy one!
