Old 12-22-2005   #8
LightningGSX
Hellbound
Re: Leaking caps, ECU ruined?
Make sure you clean up the board good and remove the coating in areas you will be soldering/desoldering with acetone.Looks like the surface mount cap (circled in pic) is trashed as well, you can replace it with a non surface mount 0.1 uF ceramic cap.Make sure you clean the board again when you're finished soldering, flux(from the solder) is corrosive.
-Nulli Secundus-
