Old 01-30-2006   #25
Re: Starting problem
Yes, when you turn your key to the "ON" position, it charges your fuel system and get it up to preasure (the pump only runs for a split second). When you begin cranking the engine the pump will of course be on too. Once the car is running, does it stay running? If I were you I'd replace the O-ring going into the fuel rail and the O-ring on each injector top (might as well do the donuts going into the head too). If that TNT place of yours doesn't have any, the Mitsu dealership will.
