Go Back   MitsuStyle > Hosted Support Forums > LSE Performance
Old 03-11-2006   #2
Re: Engine Rebuild
At this time we don't offer OEM rebuilds. Our minimum for rebuilding motors is Weisco pistons on Eagle rods. With how far these DSM's are pushed, it does not make sence to rebuild it using OEM rods or pistons.
Our shortblocks start at $2700 w/good cores. This is a Weisco/eagle combo with king bearings, all machine work, new front case, and I believe a gasket set.
Your crank might be okay, it just depends upon how bad the bearing is. You can have it turned to a "10/10" if its that bad, and have it re nitrated. Otherwise a good crank goes for the $100-200 range on the used market.
niterydr is offline
