Old 04-15-2006   #9
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
Re: Do you have to keep the charcoal canister?
all of the extra "exposed" nipples on the throttle body need to be plugged off. You can buy these small rubber plugs at most auto stores.
You need to block off the emissions portion of your block that's close to your throttle body. It will have 2 BOV looking units on it I believe. It will have a diamond shaped base with 2 emission holes and 2 bolt holes. You need to buy a block off plate or make one out of some sheet metal and remember to use RTV or some shit to make it a clean blockoff.
Some people think it helps your gas mileage and doesn't effect your performance. Others disagree. I've met some people from other states that have to keep emissions and not one of them was hurt by it. They all ran well and were pretty quick. The only reason I take them out is because it cleans up the engine bay considerably. I forget how many feet of vacuum you need but I'd assume it's important to make sure you have at least the minimum required amount. I've never really seen a problem with that though.
- Josh L.P.
