Old 06-15-2006   #11
Re: 2.4 crank pulley crizzap
I had to go and buy a 600 ft/lb impact when I couldn't get a pulley off a Honda. That puppy does the trick every time. You can also crank up your compressor a bit more for special stuff like that as well. I normally have mine at 100 psi, but I crank it up to ~130 psi if I have a bolt that won't come loose otherwise.
And the 6-bolt 2.4 I have uses the DSM crank pulley, trust me, it's only the four bolts. I had the pulley and the timing belt cog all come off and bend some valves at the SO a few years ago. Now I always loctite the large bolt.
