Old 07-26-2006   #14
Turbocharged
Re: Motor build
Originally Posted by sleepydsm
So there is a difference between a "G4CS" and "4G64" stamped block? And why is the apparently different G4CS "better"?
The g4cs 6 bolt found in hyundia's. The 4g64 is a 6 or 7 bolt that is found in galants (I'm not sure of years on the 6 and 7 bolt 4g64's). Both blocks where manufactured by mitsubishi. The only difference is that the g4cs has a threaded boss that accepts a knock sensor. I have no direct experience with the 4g64 blocks, but I have heard that they do not have a threaded boss in the same location. I've even heard that some 4g64's require plugging of coolant passages. Again, I have no experience with 4g64's but my g4cs went flawlessly.
Basically, it sounds like there are less possible headaches with a g4cs.
2.4L g4cs, 8.8:1 compression, arp hardware, eagle rods, wiseco pistons, 50 trim, TRE transmission, SBR 3500, 880's, DSMlink, methanol injection, FP2 cams, ported 1g head, spearco FMIC, walbro 255, ect.
Turbocharged is offline   Reply With Quote
