Old 07-31-2006   #11
Re: Found MY Problem
Also, I plan on double pinning these new forks. Where do you ideally want the second pin to go? Above or below the oem pin? Parrallel or Perpindicual with it? I'm assuming you use the same size pin as the OEM one in the second hole as well.
