Old 08-11-2006   #5
96 Gsx Awd
96 Gsx Awd's Avatar
Send a message via AIM to 96 Gsx Awd
Talking Re: I have some important questions please help??
Originally Posted by EclipseGST
Yes like CVD said, you need a 6 bolt flywheel.
6 bolt and 7 bolt head gaskets are the same. Depending on what year head you have, it could be just as good as any 6 bolt head. If it is from a 95-99 then it will have smaller intake ports which can be better for spooling smaller turbos.
(Dont forget to have the head drilled out to fit the larger head studs)
You also need to keep the 2g starter plate that bolts to the block behind the flywheel. Take it off of your 7 bolt block and bolt it to the 6 bolt block.
Thanks for answering the head gasket question, i did know all the rest about the starter and getting the head drilled out one size bigger but thanks for all the info appriciate all i can get from anyone.....
Finally tuned and fully built, Takes a lot of time,patience and money!!
96 Gsx Awd is offline   Reply With Quote
