Old 09-01-2006   #17
94talonawd
94talonawd's Avatar
Send a message via MSN to 94talonawd
Re: 16 Turbo lag
Originally Posted by MYTOYZ
3rd - 5th is not too bad. It just feels like a slug in the first 2 gears.
My clutch issue is probably not helping since it chatters if I try to launch over about 1800 rpm so I am not laying into it until the clutch is fully released.
I used to have a 92 Laser RS AWD Turbo and it spooled alot quicker with the stock 14b, that's what I am comparing to.
What are all of your mods?
If it is a boost leak like what some are saying, it would have to be extreme. And If the leak is that big, your car should sputter. Does it sputter under boost?
Check your manifold to see if it is cracked (Most likely it wont be cracked, unless you still have the stock 1g manifold). Also check the four bolts on top of the manifold that holds onto the turbo and make sure they are tight. If they are tight, check the metal gasket that lays in between the manifold and the turbo. My guess that there is a leak somewhere around there, causing air to escape and not spinning the turbine wheel like it should, and causing slow boost build.
I would also consider looking at the wastegate flapper to see if their is a crack on the housing (i highly doubt thier is a crack though, but just incase) causing air to go pass the wastegate and not spinning the turbine wheel like it should.
Check also to see that your wastegate is tight. Not moving freely. Make sure the wastegate flapper is closing all the way.
My .02 cents.
SOLD
94 Talon AWD
Big 16G
SAFC-II
99 Civic D16 - EVO3 16G - Hondata S300 - Xenocron 4bar@21PSI - RC750cc's - Eagles/Vitara - Compcams
12.3@114, 1.81 60ft
-On it's way to 11's....
94talonawd is offline   Reply With Quote
