Old 09-03-2006   #29
rst95eclipse
Re: 1g 2g swap complete...Wont start
If you're positive that it's the ignition, start with the plugs and work your way back. Plugs, wires, coil, wiring harness, ECU. Check your ground. Make sure you're timing is correct.
