Go Back   MitsuStyle > Hosted Support Forums > LSE Performance
Old 10-17-2006   #1
PTE turbo sale! 02 housing sale! Make BIG POWER for spring.
All your favorite pte turbo's are on sale.
The entire "SC" series of turbochargers "50 thru 61". These are the Journal bearings, ball-bearings are not on sale at this time.
"SC50" is the 450-460hp turbo. This turbo features the 50mm compressor whel. Your choice of a T31 exhaust wheel in either 69 or 76 trim (69trim is the 450hp turbo, 76 trim is the 460hp turbo).
Your choice of T04B or T04E covers. (5031 series only, 5027 series, aka the 450hp turbo, is T04E). At no additional cost. Flanged for a t3 or mitsubishi bolt-on at no additonal costs. Your choice of .36 to .63 a/r exhaust housings as well (not all flange styles support all the available a/r housings. Please call for more details).
Retail price: $999.00. Sale price $719.00
Internal wastegates please add +$73.99. Your choice of standard or heavy duty wastegate actuator.
"SC32" is the 480-490hp turbo. This turbo features the 55mm compressor wheel. Your choice of a T31 exhaust wheel in either 69 or 76 trim (69trim is the 480hp turbo, 76 trim is the 490hp turbo).
T04E compressor cover.
Your choice of exhaust housing. Flanged for a t3 or mitsubishi bolt-on at no additonal costs. Your choice of .48 to .63 a/r exhaust housings as well (not all flange styles support all the available a/r housings. Please call for more details).
"SC34" is the 535-545hp turbo. This is the 56mm compressor wheel. Your choice of a T31 exhaust wheel in either 69 or 76 trim (69trim is the 535hp turbo, 76 trim is the 545hp turbo).
T04E cover.
Choose your exhaust housing. Flanged for a t3 or mitsubishi bolt-on at no additonal costs. Your choice of .48 to .63 a/r exhaust housings as well (not all flange styles support all the available a/r housings. Please call for more details).
"SC44" is the 550-580hp turbo. This one runs a 58mm compressor wheel. Your choice of a T31 exhaust wheel in either 69 or 76 trim (69trim is the 550-565hp turbo, 76 trim is the 565-580hp turbo).
T04E covers. This one is flanged for a t3 or a t4. Your choice of .58 to .96 a/r in a t4, .63 a/r in a t3 exhaust housing. (Please call for more details).
"SC52" is the 600hp turbo. This one runs a 60mm compressor wheel. It features a t350 exhaust wheel in a 76 trim. They also feature a T04E compressor cover.
Flanged for a t3, t4, or mitsubishi bolt-on at no additonal costs. Your choice of .63 to .85 a/r exhaust housings as well (not all flange styles support all the available a/r housings. Please call for more details).
"SC60" is the 600-610hp turbo. Your choice of a T31 exhaust wheel in either 69 or 76 trim (69trim is the 600hp turbo, 76 trim is the 610hp turbo).
T04E compressor cover. Flanged for a t3 or mitsubishi bolt-on at no additonal costs. Your choice of .36 to .63 a/r exhaust housings as well (not all flange styles support all the available a/r housings. Please call for more details).
"SC61" is the 630-680hp turbo. This has the 61mm compressor wheel. Your choice of a T350 (630hp capible) or t04 exhaust wheel. The T04 exhaust wheel in either 69 or 76 trim (69trim is the 650hp turbo, 76 trim is the 680hp turbo).
Your choice of T04E or T04S or T04SP covers. At no additional cost. Flanged for a t3, t4, or mitsubishi bolt-on at no additonal costs. Your choice of .58 to .81 a/r exhaust housings as well (not all flange styles support all the available a/r housings. Please call for more details).
Some of the above turbo's are also available with a T04S cover instead of the T04E cover. Call for details. Most of the above listed are available as a mitsubishi bolt-on solution as well.
Think you are building a drag car or a street monster?
PTE also has the "bigger stuff" on sale.
PT67GTQ thru PT76GTQ retail price $1549 Sale price:$1169.00
I won't go thru the options as there are way to many! Call me if you think you need one of these.
PT70GTS thru PT76GTS retail price $1642 Sale price: $1269.00
Again, if you THINK you need one of these, call me and we will discuss options.
Finally, if you want to purchase a LSE/LIPP cast stainless steel 02 housing to go with your internally gated mitsubishi flanged pte turbocharger I can work a better deal.
Retail price of "SCM" series of turbochargers $999.99 + $81.99 for wastegate actuator
Retail of LIPP 02 housing $249.00
Total "cost" $1330.98
Sale/Combo price: $1000.00
Thats right. This is a deal you can ONLY get at LSE Performance. Get an 02 housing that will EASILY support your internally gated bolt-on Mitsu turbo. Get a heavy duty wastegate actuator, and "customize" your mitsu bolt-on to suit your needs. These 02 housings have been tested on everything from a td05-14b to a SCM61 with a 2.4 with the same results...no boost creep and great power! I currently have 10 of these 02 housings instock with 25 more on order. With this Combo you can bolt-on your turbo and 02 housing with no worries. All you need is coolant/oil feed and drain lines and an intake! It has never been this easy to make big power at such a huge savings.
All prices plus tax. Sale ends December 31st, 2006.
niterydr is offline
