Old 10-19-2006   #9
Re: Anyone else see a problem with this?
How did he get a FPR that completely cuts off all flow at idle? He could actually do it just using a rising rate FPR on his stock rail and injectors although he could only run real low boost. You could run larger injectors by running a FPR that has an adjustable rising rate ratio(more than 1:1) and running a lower base fuel pressure.
