Old 10-19-2006   #11
Re: Fuel pump not turning on with ignition
Originally Posted by Goat Blower
You swapped out the large MPI relay under the stereo, right? Check the wiring to the MPI relay and see if you're getting a signal from the ignition. You might have a bad wire between the two or a bad ignition switch.
Yes, that is the relay I swapped out. Stupid DSM's. Whats the best way to check for a signal?
