Old 11-19-2006   #3
rst95eclipse
Re: 6 bolt swap
Use Magnus. I believe the only 1g accessory you use is the water pump. Otherwise everything bolts up from the 2g (PS, A/C, Alt.). You will need to trim the drivers motor mount to accommodate the pump. Other than that, it doesn't matter which head you use.
http://www.magnusmotorsports.com/tech/1gina2g.pdf
