Old 11-30-2006   #3
rst95eclipse
Re: please inform me about pro's/con's of dsmlink
Your CAS questions are pretty straightforward. I'm not 100% sure that the 1g does not have a distributor, but I'm almost certain that it does not (since I'm most knowledgable in 2g's). The hall effect CAS sensor is the most accurate CAS that Mitsu produced. It really shouldn't matter what CAS you use, but the hall effect (black top) is the most sought after. You can certainly make a COP setup work on a 1g. You can also go after the one coil setup as well (stock).
