Old 01-20-2007   #4
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Re: Rust Repair
Originally Posted by rst95eclipse View Post
How bad is it? If you look in the gallery, I have pictures of my car. Take a close look at the wheel wells. I used a grider with a wire brush. I have since primered it so that the humid air won't create rust. I have purchased 4 bottles of 3M Rubberized Underbody Spray (can looks black with marroon accents). From what I've been told, it's the best thing you can use. If you have a hole, where you can look into your car, you'll definately need to patch it and then spray.
Yea its a hole about 1 inch wide and 1/2 inch tall, and I'm trying to figure out how to patch it cause I've never done body work before and I don't have a welder nor can I weld. If I fix it I'll fix that whole area cause I duno where else the rust has gone in. I have a can of that 3M stuff but haven't ever used it yet. I'll def. put it on after I fix the hole. I'm trying to figure out how much it would cost to just get it done by someone.
