Old 01-25-2007   #19
Re: Results from evo cam install & alky
So, an update. First off, the car is solid, and has been since it left DB. I took s2kracka and m3guy for a spin the other night, I'm sure they can attest to its gutsyness. No it does not have 500whp, but DAMN it is fun to drive like this! The car seems to just jump ahead of anything else on the street, and with the ACD in 'Tarmac' mode, the rear end is squirrelly with just me in the car. I swapped out the fresh set of BPR7ES plugs gapped at .026" with some BPR8ES plugs gapped at .022" based on what I have read others use w/ alky. The car feels about the same at 24.5psi, no change.
I picked up an openport cable to do some logging with, and found some interesting results. Bumping up the boost about an 1/8 turn on my MBC looks like it brings peak boost up to an even 25psi and all is stable/dandy (knock count in the 1-2 range). If I do a run through the gears from first or second up to about 80 or 100mph, 0 knock, clean as a whistle every time. If I do a third or 4th gear pull, that is when I see a bit of knock, and it's only at boost onset.
If I bump it up a little more to 26, knock count rises. It's probably at a safe level, but it's higher than I want it to be (knock count in the 5-8 range). This is where I'd like the car to be, and it should be able to be leaned out a bit (current afr's are 11.2:1, see my other thread). At this boost level, IDC's hit 93% at 7300rpms, so I am not running out of fuel on my stock injectors.
If I crank the boost goes up further to 27-28psi, knock count goes up to 11-12 and the car even hit fuel cut once (or boost cut, not sure if there is a difference).
So, I'd like to be at 26psi with 0 knock, maybe 1-2 like I am at now, but I'm not sure what exactly is holding me back. There are people all over evom claiming to be running my exact setup with denatured alcohol and running 26psi no problem. Now, maybe they haven't logged their car and get a little knock at that boost level, I'm not sure. At this point, the only thing I can think to try is to swap out the alky for meth, or a 50/50 meth mix w/ H2O. The thing is, chemically they are so close there shouldn't really be much of a difference.
Does anyone have any input?
